Question about Yamaha RX-770
I have a Yamaha RX770 receiver, it suddenly stopped working. I replaced the blown fuse on the board. Tried to turn it on - It blew the fuse again. Do I need a new transformer?
5 Suggested Answers
  • 1153 Answers
SOURCE: YAMAHA R-V701 MAKES BUZZING SOUND & WONT TURN ON
This could be the indication of an open resistor, or bad Capacitor in power supply. May not be visible to eye, but if you look in PS. there should be atleast one big sized cap and every PS has a bridge rectifier, this is usually 4 diodes in series, check them and see if any open, shorted
Posted on Sep 06, 2007
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
SOURCE: Yamaha rx770 stereo receiver
I have the same receiver with the same problem. I fixed it by using a cleaning spray on the inside of the input switch. Deoxit 5 is the cleaner and it took care of the problem.
Posted on Jun 28, 2008
SOURCE: where do I find and how much is a transformer for
You can find a NEW transformer for you RX-700 at Best Buy. Link below:
http://bestbuy.partsearch.com/Model/Yamaha+Electronics+Corporation/Yamaha/RX770.aspx?SearchTerm=True
Posted on Sep 10, 2010
HI. My Yamaha D80 while playing gave a burned smell and than sound quit. Rest works. I opened rearcover and notice 3rd fuse in the back was blown. Changed it. Blew again. So I stopped fidling around.
If the fuse blows and a smell of burning is present then its obvious there i a fault somewhere ahead of the fuse, the fuse is a protection device.
Oct 08, 2016 | Yamaha Cars & Trucks
How do I fix my yamaha receiver? I turned it up and it shut off,tried to turn on heard fuse blow. Replace one of the two fuses 10A 125v that one blew also.
Fuses blow due to an overload. What has happened in you case is one or more of the output devices (found on the big heat sink) has shorted and acting like it was a piece of wire. Now you have to find out which. By the way it might have gone due to bad speaker wires or speakers, or speaker wires touching each other.
Jan 11, 2016 | Yamaha HTR-5890 Receiver
Ignition fuse keep blowing in my 2003 cavalier
u have a dead short on main live wire check for overheated wires
Jul 10, 2012 | 2003 Chevrolet Cavalier
No sound: The receiver has suddenly stopped giving out any sound, regardless on which input I use. Have tried powering off/on (disconnecting all power), and checked front-speakers on another receiver.
That sounds like you blew the fuses inside the receiver. Take the cover off and check them. Typically thats the problem and if I'm not mistaken they are AGC-5 Buss fuses available at your local hardware store.
Aug 10, 2009 | Yamaha RX-V663 Receiver
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Yamaha RX-770 Logo
46 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
