Question about Kenmore Elite HE4 Electric Dryer
Nothing lights up and there is no response when I press any of the buttons. THe dryer won't start.
    Brigadier General:
  • 3,301 Answers
There is a fuse located in the rear panel of the drier,, its a thermal fuse and will blow if the machine heats up or binds in anyway,, check to be sure you have easy flow in the ducting of the drier, as this is usually what causes the fuse to blow ,, replacement is easy be sure to have it unplugged at the time of replacement for safety,,
Posted on Sep 10, 2010
When I was ready to press the On button on my dryer, I noticed the control panel locked light was lit. So I began to press any button, still nothing happened. Since this dryer was donated to me and my
Your model number does not appear to be a valid or complete number, there should be a key on the panel that shows a little lock, this key should be pressed for about 3 or 4 seconds till the lock indicator goes out. Pleazer Appliance...
Dec 16, 2014 | Whirlpool Dryers
I have the LG Model# DLE1101W dryer. The dryer will power up but when I go to start the dryer after I put a second load in, I get a series of dinging sounds when pressing the start button and the drye
Id like to see if I could help you so you will have to use more definitive terms, "Start" I'm guessing that you mean that the drum doesn't turn? (the lights come on and you push the start button and the drum does not turn) If that's the case I would start with the door switch, Best to start with the most obvious first. Try jumping it to over ride wait your response
Sep 17, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
Does not respond to button press and won"t turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 31, 2011 | Kenmore Elite HE4 Electric Dryer
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Have a Frigidaire Gallery Series front loading dryer and it keeps giving me an error(?) code, E68. When I start the dryer, it runs for a couple of minutes and then It starts beeping and flashing this code...
Sorry to read about your problem. this should be your E68 problem
You have a defective button on the control board.
The best thing to do is go into the diagnostic mode.
Turn the dial to Normal. Press and hold the Select and Pause/Cancel keys for 6 seconds, or until the Drying/Cool Down/Press Saver/Clean Lint Filter lights come on.
Then press the Start and Pause/Cancel Buttons 4 seconds. This puts you into the diagnostic mode to check the keys. Now, turn the dial 4 O'clock position, or 75. This will allow you to check all your buttons. As you press each key, it will light all the lights above it. When you press a key and it does nothing or the lights above any certain key stays on without pushing it, this button is stuck. If you can't clear it, you probably have to replace the control board.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Frigidaire Dryers
My dryer when to begin to work stop and show E68 the dryer is gallery series thanks for help me
Dec 21, 2010 | Dryers
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer won;t work
Remove the top cover and take a hair-dryer to the PC boards on the back of the main control panel.. (3 screws take the top cover off from the back) Mine has done it a total of 5 times now.. what it needs is all new buttons installed.. or a new control panel if this works..
Feb 22, 2008 | Kenmore 82822 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
