Question about Maytag Neptune MDE4000 Electric Dryer
My Maytag Neptune Dryer (MDE4000) won't stop. The timer advances right past the "Off" position and keeps on going around and around until we open the door to stop it. The dryer gets very hot.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
My maytag Neptune dryer is not working. It makes a noise when you hit the start button but doesn't start. The timer continues to go until it reaches stop. Have checked belt and it seems to be fine? Any...
I have worked at sears appliance have come across exact or similar problems. You push the button and you hear something like a loud buzzing. My experience has been that the drive motor is locked and needs replacing. Depending on the age of the dryer and the cost of a motor and installation, you might but another dryer.
Mar 03, 2015 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune dryer timer won't stop
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Jul 08, 2008 | Maytag MDE2600 Electric Dryer
My maytag neptune MDE5500AYW will not stop unless it is unplugged
if you have it on time dry and it counts down but won't shut off you most likely have a bad computer board,part number 33003028 and it's around 180 dollars.on older machines it would be a problem with the timer not going to off but you have a computer board in your machine and it takes the place of the timer and other functions,just about everything runs through the computer board.
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
My Maytag DE4000 timer will not move once the dryer is started. The dryer will run until manually turned off.
there is a clock motor in the timer ether its not geting power or has a striped gear if you can hear it runing then its the gear
Oct 20, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer,timer switch won'tmove & cool air only.
Begin by replacing the times. Then you will most likely find that you are back in business.
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer want run I can hear a noise in the timer or selecton button
unplug machine and turn start timer all away round and plug in and restart hope helps if not my need timer
May 09, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Jan 01, 2009 | Maytag Neptune MDE4000 Electric Dryer
Neptune Dryer Time keeps going forever
your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE4000 Electric Dryer Logo
132 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
