I`ve got an old Guyatone PS-011 Distortion/sustainer guitar effects pedal which i understand is now owned by Maxon & i want to boost the `level` of the effect without affecting the tone or distortion so i need the circuit diagram to be able to do this. Please email this to pauljackson74@talktalk.net Thankyou so much
ThaMp3Doctor
  • 8596 Answers
SOURCE: PD-6030 MP3 Voice recording distortion
MyMusix's PD-6030:
Manual can be found at www.mymusix.com
EQ setting
Select from "Normal, Rock, Jazz, Pop, Classic, Bass" .
You can also select "Exit" to keep the original settings.
Menu Tree Diagram is on p.29
For "password" question - there is no password, the lock on the player has simply been engaged - slide it to the unlocked position. See manual for details.
-Tha Mp3 Doctor
Posted on May 24, 2008
  • 3 Answers
SOURCE: My amp won't play distortion.
Hello all you have to do is turn your master volume down to just barley on then turn your pre amp volume somwhere about 2:oclock depending on how much distortion you want ajust your volume on your guitar a little past halfway to give yourself some headroom in case you need to turn up some while you are playing! just think of it as your guitar is your first pre-amp then your amp is second preamp in line ,that is your over drive ,then the master volume is how loud you want the overall volume i hope this help's ya!
Posted on Dec 28, 2008
  • 238 Answers
SOURCE: Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Posted on Jan 24, 2009
SOURCE: The Distortion Pedal has no effect on the sound.
i got d same problm. i fixed it myself.. check all the op amp ic's if they're all gud. if youre not sure, replace all 4 rc4558 ic's. in my case, i still felt a very small output signal from my pedal (equalizers, vol n gain ctrls r gud since they vary when i change the setting) so i suspected that one or 2 of my ic's were damaged. i only replace d last two op amps which my signal passes thru. i also had this problm with my marshall drive master. same diagnosis and solution. check your schematics
Posted on Feb 13, 2009
  • 1137 Answers
SOURCE: digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
Posted on May 26, 2009
Name some best Distortion Pedal. Where to buy them?
The best top 5 distortion pedal are:-
  • BOSS Audio DS1 Distortion Guitar Pedal
  • Pro Co RAT2 Distortion Pedal
  • Boss BD-2 Blues Driver Guitar Effects Pedal
  • Electro-Harmonix Nano Big Guitar Distortion Effects Pedal
  • Electro-Harmonix Soul Food Distortion/Fuzz/Overdrive Pedal
I use to buy any distortion pedal from this site
Top 5 Best Distortion Pedal You Must Buy New 2017 Musical Study as they guide the best to buy the best.
Jan 02, 2017 | Music
Peavey classic chorus 1991 -how do you connect a distortion pedal the power amp jacks at rear tried affects loop in front bid drop in power-do you connect same way as effects loop with send /return
Pedals operate at a different level then rack units that go in the effects loop.
It needs to go in front of the amp input. Guitar to pedal to amp input.
Nov 12, 2016 | Peavey Music
Boss ME-70 distortion changing mid play why.
Is distortion changes like we turn the OD/DS selector (changes to Boost-Natural-OD1-Blues etc)?
If so, the OD/DS potentiometer need to replace.24346541-2ss5ycyvkoajtv035dpuezke-4-0.jpg
If the changes are like increasing/decreasing GAIN/BASS/MID/TREBLE/LEVEL and also TYPE of pre-amp, then one of PREAMP potentiometer is bad.24346541-2ss5ycyvkoajtv035dpuezke-4-1.jpg
May 06, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
When i plug an MXR micro amp (volume boost) in front of the supersonic, it works on the clean channel but does not affect the burn channel, Why? By the way, when plug in to the effect loop it does work...
DO NOT USE a guitar pedal in effects loop as it has the WRONG signal levels.
Also, when you boost the gain preceeding a distortion setting in an amp, the amp will just limit out and it will appear that the effects in the amp aren't working... but what is happening is you wind up with too much input signal and the "flat topping" distortion occurs right at the inout of the amp so no further can occur when you select a distortion in the amp.
Jun 22, 2011 | Fender SuperSonic 22 22W 1x12 Tube Guitar...
How To Use The effect Loop?
The effect loop is to use exteernal effect module... It is NOT to use guitar pedals !!!! The signals are line levels, NOT guitar type levels. An example of a device might be an Alesis Quadraverb. You take the effect send jack and run it into the inout of the effects module and the output of the effects module into the effects return jack. Many try to use guitar pedals and massive distortion results because levels are too high for the pedals.
May 12, 2011 | Peavey 6505+ 112 Combo Amp Combo
Fulltone Clyde Deluxe wah distorts and interferes with other pedals, along with a narrow pedal range for the effect, though the pedal has a full sweep. I have gotten no answer from Fulltone on the...
The best way to understand the problem source is to minimize the components. In this case, try the pedal alone first. You need to determine whether or not the pedal is causing the distortion. With the pedal alone, how does the system sound/work? Is it acceptable and performing as expected? If so, then the next step is to add one more effect in the chain. Try the effect BEFORE the Fulltone first. Does the distortion appear? If so, then the problem is likely in the input stage of the Fulltone. It should be able to handle mic level inputs. The effects you are using should be outputing the same level as well. If you are unsure of the output signal levels of the effects, set the guitar to a fixed level and insert one effect at a time. The overall signal level should be similar for each one at the "unity gain" setting.
Please try a few options as suggested above one at a time and report the results here inas much detail as you can. This should help to resolve the problem.
Dan
Mar 15, 2011 | Fulltone Clyde Deluxe Wah Effect Pedal NEW
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
187 people viewed this question
 Grubhead
Grubhead
