Question about Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25PQXF
My compressor runs constantly - Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25PQXF
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
LG Model: LWHD1500ER - I would like the unit's compressor to remain on constantly. The temp guage seems to be off and shuts down the compressor. Can I bypass the temp guage to leave th ecompressor...
You can but the unit will have not control over temperature, and you can cause the unit to freeze up or slug the compressor w/ liquid refrigerant causing premature compressor failure. I would recommend replacing the thermostat if it is not holding proper temperature, but if dead set on bypassing it use a volt/ohm meter after unplugging it to find the normally open contacts and wire those wires together taking into consideration that the fan must run constantly with the compressor.
Sep 23, 2011 | LG LWHD1500ER Wall/Window Air Conditioner
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
Compressor motors are constantly grounding each time the compressors are replaced. A new run capacitor is installed with compressor. A thorough cleanup and evacuation is performed with each compressor...
dear sir
please make sure your electrical connection to the compressor is correct and tighten. electricity supply is straight and not fluctuate i mean constant supply for unit and then change new run capacitor and make sure ground wire must connect to the air conditioner,s body and check copper filter and any other copper pipe is not block .
i think it cab be an electrical problem so check all electrical device and then re-install new compressor.
thank you
hope answer the question
please vote!
Oct 02, 2010 | LG LS180HE Split System Air Conditioner
My kenmore 19.7 cu.ft. chest freezer is not running and the compressor is hot
Place a volt meter set for amp draw around one wire of the compressor. If you do not have a constant amp draw replace the start relay on the compressor.
If you do have a constant amp draw the compressor is bad or you have a refrigerant leak.
Apr 25, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
The fan runs constantly. The compressor starts,
Check the compressor run capacitor first.
Jun 21, 2009 | Kenmore 53701 Dehumidifier
Compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
May 10, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Fan / Compressor runs constantly
Condenser fans (the fan next to the compressor) do run all of the time. That is normal.
Sep 18, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Hissing sound and constantly running generator
The only thing I can think of that you may be hearing would be if the compressor has a problem. If you notice cooling performance decrease or it stops cooling, I believe you will find the compressor has bad internal valves. It will probably take a technician to properly diagnose this and if the compressor has this problem the only answer is to replace the compressor.
I hope this helps, supertechks
Mar 28, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
