Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint wdl520 water leaking from the dispensing tray only on the first spin cycle
dazmaraz
  • 67 Answers
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Posted on Mar 07, 2008
  • 240 Answers
SOURCE: water leaking from the soap dispenser during rinse and spin cycle
use liquid instead of powder and always use HE detergent
Posted on Apr 26, 2009
SOURCE: water leaks from the soap dispensing tray on Hotpoint WMA 56 model
No Problem glad to assist.
Posted on Dec 29, 2007
barkencoa
  • 3463 Answers
SOURCE: Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
Posted on Feb 02, 2009
  • 109 Answers
SOURCE: hotpoint aquarius WDL520 all lights flashing not
There should be a small door at the front bottom of the machine, open it and unscrew the plunger. try that first as there could be a blockage.
The machine will not spin until the water is drained out.
Posted on Jun 17, 2009
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius WDL520 all lights flashing not spinning water still in bowl cant find instructions only bought it at xmas
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Leaking machine
Could be caused by several reasons.
1- Overfilling, check water level .
2-Blockage in dispenser, or dispenser inlet hose to drum
3-Drawer not in properly.
4-M/c not draining properly, thus when it goes into spin, water could be thrown up by centrifugal force, and come out of the front of the drawer.Check filter.
5-Water pressure very high, forcing water out of drawer, adjust pressure.
Plz rate my soution.
Thanks.
Dec 30, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint aquarius washer dryer!
The water is coming out of the dispenser because it is going into spin with water in the drum due to it not draining properly.
So you need to check the filter.
If there is no filter at the front bottom of m/c, then you need to remove the lower rear panel on the m/c, locate the large black hose going to the bottom of the drum, undo the clip[ securing hose and remove hose.
There you will find the filter, remove and clean.
Check the pump at the same time for any obstruction.
Refit hose, making sure you get it on properly.
Test for leaks before fitting back panel.
Plz rate this solution.
thanks.
Dec 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Intermitant water leak.
Put a newspaper under the machine, it will help you to find out from where does the water leaks. Good luck!
Sep 06, 2007 | Hotpoint Ultima WF865 Front Load Washer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
353 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
