Question about Acer Aspire One PC Notebook
My screen is dark on my Acer Aspire One D260 even though the computer has booted up.
  • amysuggars Sep 10, 2010
    Yes, I tried that and the screen actually gets a but lighter. But it is still blank. There is no display.
    Master:
  • 515 Answers
Did you try to turn it brighter with the graphic options. You can right click on the screen where no windows open and choose graphic options or graphic properties from the pop up menu or something about display or graphic if you are using some kinds of display cards. Then you can adjust the bright and contrast of the screen. Or you can try to use the buttons on your LCD for that if any. The screen may be brighter with your power cord on so the battery will last longer as one of the power saving plan you can specify in the power options of control panel. You can adjust that plan so it will not become darker with only the battery. Also you can check the LCD connections and the backlight circuit but those takes a lot of manual reading and screws work.
Posted on Sep 10, 2010
  • Donald Huang Sep 10, 2010
    So you did not see any logos or text displayed on the screen, right? I will suggest you to boot in safe mode or the Last Known Good Configuration by pressing F8 when booting up (hold it down when you restart your computer). Or you may try to enter system setup (BIOS) by pressing the key for that described on the manual. Mine will display a message telling me to press F2 to enter system setup. There I can check whether the hard disk is one of the booting device. Make sure there is no CD, SD or flash drive plugged in when you restart. If that does not bring up anything, then you may need to check whether the processor is tight on the mainboard and whether the hard disk is connected properly. Open the case and reconnect the hard disk and press the processor towards the mainboard if necessary. If you did hear the fan turning and there are sounds about your operation but no display, you may try to connect another monitor to the VGA port on your laptop. If that will work, then you may need to check the cable connection to the LCD and make sure it is through. Sometimes a factory default restore will also help if the drivers are corrupted and some virus are on the disk. You can see how to do that on the manual too.
I flashed acer d260 and changed the ram is the hard drive corrupted?
Couple of questions
What error/s are you getting? ie
  1. do you hear a post beep sound
  2. does the screen show any error (take a shot and post)
  3. does windows bootup?
May 13, 2014 | Acer Aspire One D260 Netbook
The screen on my acer asire/E won't turn on even though it is powered on.
could be what they call the inverter thats gone..or your screen has gone..to find out if its your screen thats faulty just put another monitor to your laptop using a vga cable ,if your windows show on the monitor then its your laptop screen or the inverter thats gone.
Apr 20, 2014 | Acer Aspire One PC Notebook
Acer aspire doesnt boot
You are missing the Windows Boot. No Operating system!
Dec 05, 2013 | Acer aspire 5733z4851 intel pentium...
Flicker screen
To check where the issue lies, firstly plug in an external display.
Nov 30, 2013 | Acer Aspire One D260 Netbook
How do i brighten the screen on an acer aspire d260 the screen is so dark i caint make anything out
go to the desktop and press F1. type in change screen brightness and it should show you.
Jun 11, 2012 | Acer Aspire One D260 Netbook
How to get into the bios
When you boot up the screen will display the function key you need to press to go into the BIOS. This may be F1 or F2 etc.
Feb 09, 2012 | Acer Aspire One D260 Netbook
I have one notebook aspire d260 notebook, but i cant start the windows, what can i do??
Hi and Welcom to Fixya!
To be sure that nothing is preventing the machine from accessing the hard drive and successfully boot to windows, remove all devices attached to the notebook. If this does not work, chances are, you might have a corrupted windows.
If you have already backup your important files (which every laptop owner should do), you can just simply reset the machine back to factory settings.
To restore Acer Aspire 1 D260-A to factory settings: press Alt+F10 when you boot up the laptop. You will see Acer Recovery Management, select "restore system to factory default settings" then follow the instructions.
Hope this helps!
Takasashi
Jul 13, 2011 | Computers & Internet
My acer aspire one d260 has no cd rom and i tried alt f10 how can i boot it
If you have tried the restore boot process without sucess, you will need to reinstall windows from either an external usb cd drive, or the more time consuming method here:
http://aspireoneblog.com/blog/2008/12/11/how-to-install-windows-xp-on-an-acer-aspire-one/
remember if using the method, to download a sata driver from acers website for the hard drive
Jan 11, 2011 | Acer Aspire One PC Notebook
I cant turn on my wifi on my acer aspire D260 laptop
The Wifi Driver for your acer might not be installed
Visit the below mentioned link and install the WIFI Drivers and then you will be able to get connected
http://www.4hindisms.com/notebook-laptop/download-acer-aspire-one-d260-windows-xp-drivers.html
Dec 20, 2010 | Acer Aspire One PC Notebook
Battery or Screen problem
Solution? - not sure yet but having read solution by Hector_ahab, tried various F() buttons in conjunction with Fn button. Pressing Fn with F6 switches between black and normal screen on my Acer Aspire 5920. Fingers crossed!
Apr 17, 2009 | Acer Aspire 4520 Notebook
Acer Aspire One  PC Notebook Logo
171 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
