Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
I get a message stating that the tv is overheating and eventually turns itself off. What needs to be replaced?
The problem could be that the filter on the back of the TV needs to be cleaned. Remove the pop out door and clean the foam filter. Do not get it wet, just use the vaccum or blow the dirt out. There is a fan behind the filter, so any dust and pet dander is filtered before the air is sucked into your unit. I make it a habit to clean mine every 6 months. I'd do it more often if your house is in a dry dusty location.
Posted on Sep 22, 2010
My LED tv screen is dimmed on the right 1/3. After some use it eventually goes totally black?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 23, 2015 | LG 55" 7400 Series LED HDTV - 55LA7400
My AKIRS tv model -LCT-26MTO5ST.WHEN ITS ON PICHURE AND SOUND HAVE ,SUDDENL 5 TO 7 MINUTES ITS TURNS OFF ITS SELF.WHEN THEN ON BACK IT WILL OFF IN FEW SECONDS, WHAT SHOULD I DO? HELP ME SOLVE IT HOW?
I am not familiar with your model of TV, BUT.... the symptoms you describe suggest that the device is OVERHEATING INSIDE, and a safety function is shutting it down UNTIL it cools enough to eliminate the safety hazard.
IF that's the situation, the CAUSE WILL NOT correct itself, and requires the services of a QUALIFIED Television TECHNICIAN!!!!!
To continue to use the TV without correcting he overheating problem will eventually result in self-destruction of the TV, AND POSSIBLY A FIRE!!!!!
Get it properly repaired by a professional technician NOW!!!!!
Jan 10, 2015 | Televison & Video
TV goes off suddenly. Searching for connection.
'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
TV loose power, then regain it...off/on 20-30 times a minute
It's trying to speak to you... it wants you to repair it. It must be where the relay is that turns the tv on with the remote control. All aging electronics needs the electrolytic capacitors replaced. When they age they throw the voltage off and cause many other parts to blow up. Aging solder joints could be a factor too. look for parts that have been overheating. The circuit board may have parts desoldering themselves and or overheating the circuit traces.
Dec 01, 2013 | RCA TruFlat 27F520T 27" TV
I have a model number PT-50LCX64 Panasonic rear projection TV. After turning on the TV about 3 minutes will elapse and TV will automatically turn off by itself.
Probably the fan isn't working or is dirty and needs cleaning. The projector bulb is overheating and shutting down the TV. Clean or replace the fan.
Jul 09, 2011 | Televison & Video
My receiver turns off and on by itself and becomes very hot
Hello, Daniel Busa with Dish Network customer service here. if your 622 is overheating you should get an errpr message stating its overheated. At that point you will need a replacement, if its turning off and on by itself sporadicly then that may be remote interference. Try this link to readdress the remote.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Nov 23, 2010 | DISH Network ViP622 DVR DTV Receiver /...
My TV has developed a problem whereby when attempting to turn on teh TV, it goes througha process of clicking itself on and off for a few minutes until eventually it manages to power up and we can watch...
For a temp.fix,tries unplug,replug the tv back about an hour later,so the tv power and other boards to reset itself.Tries websites like Shopjimmy.com.Ebay.com to buy a refurbish power supply board for the replacement.
Sep 28, 2010 | Televison & Video
TV Turns off by itself
its the tuner ic nuber 536 faulty on the main board or the capavcitor number c762 faulty.that needs replacement.
Mar 06, 2009 | Sharp 32C241 TV
Acer turning off
Yes this does sound like a mother board problem replace the mother board.
Feb 05, 2009 | Acer (ACERMOTHERBOARD)
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
