I have Samsung Automatic Washing Machine (Model WA88TPB). The Software got hanged. Nothing happens when we press any button. Is there any way to reset the software?
  • 82 Answers
SOURCE: Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Posted on Jun 27, 2009
SOURCE: Electrolux EWF 1087 - Power on, light goes orange, nothing works.
Hold reset and start buttons down, while turning on. Hold down for about 10 seconds.
If you're getting an E90 error code, which means communications error, it means you have a dodgy connection between the main board and the control panel.
Disconnect the power completely, open up the top of the machine and reseat the plugs on both ends on the blue ribbon cable connecting the front panel display to the main board. (The main board is the big white plastic thing with all the wires running into it).
Do the reset steps when turning on again, should be good to go, otherwise it's a bit more serious and you'll need the tech back.
Posted on Jun 30, 2010
SOURCE: i need a manual for WA13UP Top load(samsung) washing machine
water running out at the draining pipe the while the machine fill itself with water
Posted on Sep 02, 2010
emissionwiz
  • 77186 Answers
SOURCE: Where is the reset button
there is no reset button, the reset for the system is to unplug it for at least 3 minutes from the wall socket, if it doesn't reset then there is a electrical failure of the central control circuit board.
Posted on Sep 20, 2010
caroldon
  • 17130 Answers
SOURCE: Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Posted on Nov 11, 2011
How to calibrate samsung top load washing machine
there should be another 7 letters/numbers after wa14 maybe the full model number is on the back or in a manual
Sep 19, 2015 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
How do I reset my washing machine?
Sounds like a control problem. Try googling your make and model of appliance followed by "service manual". Most newer, digital controlled appliances have a "secret" service menu where you can check for error codes, stuck buttons, bad sensors and such. Download the tech manual and start troubleshooting. Or you can call an appliance repair tech to come out and do the same thing for a fee.
Jan 02, 2015 | Washing Machines
My phone is hanging up. as i open the inbox it got
You might update the firmware/software
Updating the software of a Samsung mobile can help improve the functionality of the device. Software updates are made available to fix security, data and other known issues of a Samsung mobile.
Updates are also available for third-party applications and to improve hardware issues such as battery life.
The updates can be initiated from a Samsung mobile handset.\
Press the "Menu" key, then select "Settings."
Select "About Phone," then "Update Profile.
" Wait for the update to complete.
Select "Update Firmware," then wait for the update to complete.
Turn off the Samsung mobile for about a minute, then turn it back on.
http://in.samsungmobile.com/support/softwaremanuals/softwareSimUpdate.do
Aug 13, 2013 | Samsung SGH-L700 Cell Phone
My Samsung fully automatic washing machine Model # WA13G2Q showing 1E error code.What do I do?
My Samsung fully automatic washing machine Model # WA13G2Q showing UE error code.What do I do? THIS IS MY EMAIL engrabih12@hotmail.com
Apr 13, 2011 | Samsung SW62ASP Top Load Washer
Zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
Iphone got hang while installing iblacklist software from installer
Had the same problem. Used ibrick to reboot. You loose nothing of the info and software you already installed on your iphone.
Apr 25, 2008 | Apple iPhone Smartphone
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
