Question about Dell Inspiron 1525 Notebook
Last night with I turned on my Dell inspiron 1525 notebook..the screen when white and shut down...I turned it back on and it kept going throught this routine over and over..I was able to keep it on long enough to get my picture off it...this morning when I opened it and pushed the power button to turn it on ...I got nothing..no power, no lights, nothing...I removed the power cord and battery and reconnected them and still nothing......lights out and no one home.....I have had it for 2 years and I am a graphic designer and had it specially built...just for the work I do..now I have a piece of junk that cost me over 1,500.00 dollars and still making payments. Does anyone have an answer to what might be wrong with it....
  • 3 Answers
Mines did the same thing. I noticed only one of the lights at the bottom left corner (my left) was on so I took of the key board and noticed the cord thing (sorry I'm not technical) that ran from the direction of the lights to the main board was not pushed in all the way.
what my computer was doing
power came on, the lights at the top lit up, fan ran then stopped, I heard the cd reader spinning for a few seconds, my screen was black, and bios did not run so windows could not open. Some times it started long enough for me to log in and open a window then it would die, and come on agiain and die, and battery would not charge.
Posted on Jan 24, 2013
  • Jasmine Swanson
    Jasmine Swanson Jan 24, 2013
  • 3,940 Answers
Here are some troubleshooting steps: like before remove the battery and the AC adapter, then connect just the AC, see if the LED on the adapter goes out or stays on. If it goes out, see if another adapter (known good is available) or see if you can try one at Bestbuy or such. If the system powers on, then replace the AC adapter.
If no power with a known good AC adapter, then the failure is likely the motherboard or the power board. You can try the powerboard 1st
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=inspiron+1525+charger+board&_sacat=See-All-Categories
motherboard 2nd
http://shop.ebay.com/i.html?_nkw=inspiron+1525+motherboard&_sacat=0&_odkw=inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1313
manual here
http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
Posted on Sep 10, 2010
My Dell Inspiron 1525 is stuck in "hybernation." It will not let me "control, alt, delete" and I've even tried removing and reinstalling the battery. Help! Thank you!
Press and hold down the power button until the computer shuts off. Then wait at least ten seconds and power it back on.
While it is booting up and you see the Dell logo on the screen, press and hold the F8 button. When the next screen appears, you will see a list of options for how you would like to continue the boot up process. Highlight the option titled "last known good configuration" and press enter. Your computer will restart and load up with all of the settings previously used before it began giving you problems.
Apr 23, 2011 | Dell Inspiron 1525 Notebook
My computerr was working fine last night I turned it on today and dell media home came up then it goes to a blue screen that reads a problem has been detected and windows has been shut down to prevent...
Driver or software update that was incompatible can cause this, try to boot to F8 and run a disk check.
Also failing ram can cause this, check the ram modules using Mem test
Dec 30, 2010 | Dell Inspiron 1525 Notebook
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 will not start up all the way. It was fine last night but all I get now is a black screen the the mouse showing. I can't turn it off unless I hold down the power button. I don't know...
boot computer when it first starts up push F8 for advance menu. in advance menu select last known good configuration. hit enter . if the computer ges to desk top do a system restore . to before the issue started. if this fails you will need the windows disk to do a system repair. your configuration may be corrupted.
Nov 16, 2009 | Dell Inspiron 1525 Notebook
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
Sep 01, 2009 | Dell Inspiron 1525 Notebook
My dell inspiron 1525 vista will not turn on
ok first remove battry .press start button for 15 seconds and now aplly battry and give sometime on charging and than press start button . enjoy good luck
Jul 28, 2009 | Dell Inspiron 1525 Notebook
Shut down problem
somthing is running in the background ... maybe spyware ... maybe just some application ... try shutting everything off manually in ur taskbar and then shutting down ..
or Else You can also right click the task bar and select "task manager" from there go to "user" and above that you find the shut down selection in one of the menus.
Mar 15, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Dell wont come boot
sound like you have corrupted the operatint system u have to redo the hard drive reinstall windows this will help
Nov 15, 2007 | Dell Inspiron 1100 Notebook
Dell Inspiron 1525 Notebook Logo
158 people viewed this question
Alun Cox
