Question about HP OfficeJet Pro K8600 Printer
HP K8600...yellow cartridge won't stay in. It pops in fine, but as soon as a print job is queued it pops out again. I've tried to forcibly hold it in but no luck. Consequently the printer won't print anything. I've tried 2 new cartridges to rule out cartridge failure...same problem. Please advise, and thanks in advance!
  • 208 Answers
SOURCE: Print jobs are not getting queued.
This is late but most likely the IP address is set to DHCP or auto and the printer is changing the IP address.
You need to set it to manual, and set the IP address static.
Those machines will change the IP address by itself.
Sometime even when you have set it manually it will change back to auto.
Posted on Dec 04, 2007
  • 4 Answers
SOURCE: my hp 1210 printer
Tax time is come asnd gone but Kinko's is just around the corner.
Posted on Apr 25, 2008
  • 137 Answers
SOURCE: Cartridge errors on HP97 / bad TSR?
Hi Scott -
Sorry, I do not have any additional ideas as it seems you have checked things I would have suggested - cleaning the contacts. (I presume you did clean the cartrdige contacts in addition to the printer contacts.) The TSR may be correct but may be encoded incorrectly, which could cause an issue as this would make the printer "think" the cartridge was too hot or too cold. The printer will refuse to print with certain ID errors. A 10-tap will bypass this test as a diagnostic aid. Does the 10-tap show a "good" nozzle diagnostic? If there are repeating missing nozzle segments across all three colors it would indicate an interconnect issue.
If the cartridges are original HP cartridges I would check the warranty date (two years warranty from date of manufacture) as shown here. If the cartridges are still in the warranty period contact HP for replacements.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Jul 03, 2008
gwbm
  • 353 Answers
SOURCE: Epson Stylus C88 puts the job in the queu and doesn't print
Have you tried running an independent printer check - see
http://files.support.epson.com/htmldocs/sc88__/sc88__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
If the printer prints the test page OK, it means the problem is with the computer. If it were a PC, I would uninstall, reboot and then re-install the driver software. Maybe this will work with a Mac?
Posted on Feb 22, 2009
  • 8 Answers
SOURCE: 4315 Hp Printer will not align.
restart your printer like this: go to control panel>
performance and maintenance>administrative tools> services> scroll down until you come to print spooler, click on this then on the upper side of your screen you will see restart, click on it.
This should get you up and running. Shame on your repair man for not showing you how to fix the problem.
You could even try not aligning the cartridges, this will just cause your printer to spit out an alignment page each time you turn it on but still should go ahead and print for you.
let me know how if this helps.
kriegersugar@yahoo.com
Posted on Mar 14, 2009
Printer won.t print ..... Before it stop printing it was throwing out a page that I was printing and wouldn't stop.
Go to the printers folder; Control panel/printers and there right click on the printer icon and select open. You should see some print jobs queued up. delete them, restart the system and try to print again. If this doesn't work, Go to the printers folder; Control panel/printers and there right click on the printer icon and select properties. In the pop up menu go to the advanced tab and look for hold mismatched documents and uncheck its box. If you do not find it under the advanced tab, skip through all the tabs to see which one has the "hold mismatched documents" option and uncheck it and click OK to exit. Now try to print again.
Good luck & god bless!
Feb 11, 2011 | Brother HL-2040 Laser Printer
My HP Officejet Pro K8600 won't print black. I have changed the printhead, the cartridge. I have soaked the printhead, I have shaken head. I am getting yellow ink out but no black. I have run every...
Materials needed: New empty syringe (big one) Gloves (to protect your hands fromink) Alcohol Paper tissue (to clean the excessink) Empty Plastic bottle (Here you putthe ink from the syringe) Important: Ensure that you have put new blackink cartridge to K8600. Ensure that the printhead arerecognized by the printer or no light alarms. Instruction: Press the Power button to turn onthe printer. Test print in microsoft excel with4 color black/yellow and cyan/magenta. If black only is missing means youhave clogged problem from the host. Wear your globes, prepare thematerials needed. Open the top cover. Press and hold the Resume buttonuntil the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left sideof the printer. If the carriage does not move to the left automatically, turnthe printer off and back on and then try holding down the Resume button again.The printhead can be damaged if the carriage is not all the way to the left forinstallation. Lift the printhead latch. Lift the handle of a printhead anduse it to pull the printhead black/yellow out of its slot. Put printhead in thepaper tissue upward. Your printer are still ON becarefull not to touch the flex copper circuit. Get your syringe, use this to pullthe ink from the nozzle cap ( see link picture) After the done the syringe method,Insert the printhead black/yellow into its color-coded slot. Press down firmly on the printheaduntil it snaps into place. Pull the printhead latch all theway forward, and then press down until the latch engages. Close the cover. The printer should align theprintheads automatically in a few minutes, printing an alignment page. Print a test with black color only,If it does not print, try to change the Printhead. This is the only solution I foundin my HP k8600 black ink problem._579.jpg
Jan 24, 2011 | HP OfficeJet Pro K8600 Printer
Hi, the magenta ink won't work on my printer hp office jet pro k8600. I have replaced it with a new one and even though is shows that it's full on the ink levels it won't print it at all, I have tried all...
Materials needed: New empty syringe (big one) Gloves (to protect your hands fromink) Alcohol Paper tissue (to clean the excessink) Empty Plastic bottle (Here you putthe ink from the syringe) Important: Ensure that you have put new Magentaink cartridge to HP K8600. Ensure that the printhead arerecognized by the printer or no light alarms. Instruction: Press the Power button to turn onthe printer. Test print in microsoft excel with4 color black/yellow and cyan/magenta. If magenta only is missing means youhave clogged problem from the host. Wear your globes, prepare thematerials needed. Open the top cover. Press and hold the Resume buttonuntil the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left sideof the printer. If the carriage does not move to the left automatically, turnthe printer off and back on and then try holding down the Resume button again.The printhead can be damaged if the carriage is not all the way to the left forinstallation. Lift the printhead latch. Lift the handle of a printhead anduse it to pull the printhead magenta/cyan out of its slot. Put printhead in thepaper tissue upward. Your printer are still ON becarefull not to touch the flex copper circuit. Get your syringe, use this to pullthe ink from the nozzle cap ( see link picture) After the done the syringe method,Insert the printhead magenta/cyan into its color-coded slot. Press down firmly on the printheaduntil it snaps into place. Pull the printhead latch all theway forward, and then press down until the latch engages. Close the cover. The printer should align theprintheads automatically in a few minutes, printing an alignment page. Print a test with magenta coloronly, If it does not print, try to change the Printhead. This is the only solution I foundin my HP k8600 printing problem.christan_11_1.jpg
Jan 14, 2011 | HP OfficeJet Pro K8600 Printer
HP OfficeJetPro K8600 is printing blank lines on the
needs cartridge? or could try cleaning the heads.
Dec 04, 2009 | HP OfficeJet Pro K8600 Printer
Delayed printing
Your problem lies in the vista software. This is a common problem where Vista cannot often read the software drivers quick enough or are not compatible which makes it not work properly. My advice would be to get rid of vista and go back to XP, it was much more compatible with everything. Problem could also be in the cable. Make sure they are plugged in nice and snug. Cheers.
Oct 02, 2009 | Computers & Internet
For some reason my HP Officeject Pro K8600 is reading empty yellow ink cartridge even after I replace it. I have replaced the cartridge several times with a new cartridge but it still won't work. Why? ...
The mount that holds the spring for the yellow ink cartridge pump arm in the service station is probably broken. You will have to replace the ink-service station.
Sep 15, 2009 | HP OfficeJet Pro K8600 Printer
HP OfficeJet Pro K8600 Printer Logo
96 people viewed this question
Seeker5211
Seeker5211
