Question about Brother LS-1520 Mechanical Sewing Machine
Can not get the tension right, to loose - Brother LS-1520 Mechanical Sewing Machine
    Problem Solver:
  • 3 Answers
The pressure foot has to be down to adjust the tension. Sometimes the tension on the bobbin can be wrong and it can appear to be the tension on top.
Posted on Sep 10, 2010
My JUKI 1541 S thread winder is winding too loose. How do I adjust it?
Are you running your thread through the small tension at the upper right of the machine before you run it down to the bobbin? If you are and it is still loose, turn that small white knob to the right to increase the tension on your bobbin thread. If that doesn't seem to be working, pull the two tension discs apart that you have run the thread through, and see if there is a piece of thread or something caught between them that is not allowing the tension discs to close as they should.
Nov 01, 2017 | Juki Sewing Machines
When I rewind my boobin, the thread is too loose. How do I adjust it on a JUKI DNU 1541-S?
You're saying the thread on the bobbin is loose/sloppy? That would be a result of the tension placed on the bobbin during winding. Make sure you are using the correct threadpath to wind the bobbin, or the winding tension needs to be adjusted.
https://www.sewingpartsonline.com/juki-dnu-1541-parts.aspx
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiikseM2J3XAhUE72MKHSV2Bg8QFggmMAA&url=http%3A%2F%2Fdanreetz.com%2Fjuki%2FJUKI_DNU-1541-S-7EM01_SERVICE_MANUAL.pdf&usg=AOvVaw250Npk5Blb-ZBGHGIFqwyy
https://www.manualslib.com/products/Juki-Dnu-1541s-3329212.html
The thread is loose at bottom
When the bobbin thread shows on the right side, the needle tension is too tight or the bobbin thread, too loose, as shown in the middle drawing at right. When the needle thread shows on the wrong side, the needle tension is too loose or the bobbinthread, too tight, as shown in the bottom drawing at right.2 Nov 2008
Understanding Thread Tension - Threads
www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+The+thread+is+loose+at+bottom
Dec 15, 2016 | Sewing Machines
I can't get the tension right. The stitches on the top side are too loose and the thread just pulls out.
loosen the needle thread tension of a bit
sew on a scrap bit of material until you get the tensions right
correct tension is when the bottom thread and the top thread meet at the join of the two pieces being sewn
you will only need to sew 1" to see how it is going
Nov 22, 2015 | Sewing Machines
Brother vx 860
First, make sure the upper thread is threaded correctly. I don't have this model but see if this helps. If the bobbin thread is visible from the right side of fabric, the upper thread is too tight. If the upper thread is visible from the wrong side of the fabric, the tension is too loose. Turn the thread tension dial to the right to tighten and left to loosen upper thread. Good luck. Loverly Lou
Jul 17, 2014 | Brother Sewing Machines
Bobbin tension too loose
You don't give us the make and model of your machine.... so it's hard to give you decent specific advice. Secondly your question isn't making sense. If you are getting loops on the bottom your top tension isn't right(too loose) if your loops are on top your top tension isn't right.(too tight) The only time you would mess with bobbin tension is when you change thread weights significantly. Like from 40 weight to 92 weight or visa versa.
Look at your bobbin case, bobbin carrier, shuttle/carrier..... there is a spring (it's a flat piece of metal) on the spring is a small screw. Use a small screw driver and tighten the spring 1/4 turn. Loosen your top tension a couple turns. (remember right to tight, left to loose)
Mar 19, 2013 | Sewing Machines
My juki ddl 8700 has a tension problem. The tension post assembly is loose.
theres a set screw to the right of the tension device. maybe its loose. the screw is part of the machine body. don't look for it on the tension device. u have to get your head down in the to see it.
Sep 16, 2011 | Juki DDL-8700
How do you adjust the tension
Tension is adjusted with the tension dial on the right side of your machine.You would adjust the tension to your comfort. Use a piece of material to practice on, and tighten or loosen your tension till your threads look just right. If they are to tight your material will bunch up, if they are to loose you will have thread loops or very loose threads. As you get to know your machine this will come to you as easy as driving a Model T Ford. GOOD LUCK.
Jul 24, 2011 | Singer 2732 Mechanical Sewing Machine
The thread underneath when sewing is too loosed
Usually thread too loose on the bottom is caused by the upper tension being too loose. The top and bottom tensions work together with the top thread making the underside of the stitch seem too taunt or too loose and the bobbin thread causing the top side of the stitch to be loopy or too tight. Select a large zig zag stick and sew a couple of inches. Then examine the stitch. It should look identical on both sides. Look to see which side is drawn too tight, the zig zag being smaller on that side with threads from the bottom threads pulled through. Then adjust the two tensions so that they make a uniform, identical stitch.
Also, when the bobbin tension is right you can hold the bobbin dangling by the thread and it won't spool out to the floor but will let loose a bit with a slight flick of the wrist. Too loose it will just spool out. Too tight and it won't drop at all. When you get that set right then do the above zig zag test to see where the top tension should be set.
Mar 02, 2011 | Sewing Machines
Euro-pro 464xc bottom tension loose
Welcome to FixYa!
Loose bottom stitches come from the top, not the bottom. Seems weird, but that's the way sewing machines work.
The dial tension should be set at the mid range and make absolutely sure that you have the machine threaded correctly. Both things will cause a sloppy bottom stitch.
Thanks!
If you find my solution helpful, I'd appreciate a FixYa rating....
Jan 15, 2009 | Kenmore 12102
Brother LS-1520 Mechanical Sewing Machine Logo
50 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
