Question about Brother SE-270D Computerized Sewing Machine
How to replace the thread cutting inside the machine
    Genius:
  • 1,788 Answers
You could just call Brother customer service, and they may be able to guide you. The phone # 1-877-276-8437. You have a very nice machine so you don't want to have just anyone look at it, be careful who does. My sister learned the hard way. Good luck
Posted on Sep 13, 2010
Thread is stuck inside my innovis-v7. can you tell me how to get it out please
Where is the thread stuck???
If in the bobbin area, cut the top thread, then try to remove the bobbin case. If unable to, gently clip threads and pull them out piece by piece until you can remove the bobbin case.
If the top thread is stuck somewhere inside your machine where you can't get to it, you may need to take it for service.
Mar 02, 2018 | Sewing Machines
Bernina 1630 keeps shearing off the needle thread resulting in a break and re-threading the needle.
Your machine may have a gouge (snag) somewhere in the thread path that is catching the thread and cutting it. You'll need to locate that area. You might wrap your finger with an old piece of hosiery, cheesecloth, or a fine knit fabric. The rough spot will catch the fabric as you run your finger around inside the machine. If the spot is small, it can be smoothed using a fine emery board or something similar. However, if it is large, the part may need to be replaced.
Jan 01, 2018 | Bernina Sewing Machines
Thread Cutter won't cut
I had the same issue with my Brother. I took it apart (by the booklet instructions) and found a thread tangled inside. I pulled it with tweezers, (used a light and never use can air). I cleaned and oiled after finished and my machines have been working perfectly since then.
Good Luck!
Nov 04, 2017 | Sewing Machines
How to replace a broken spool pin on a brother xr40 sewing machine?
Search for:
Make Model replacement parts
Vendors like Sewing Parts Online may have what you need. If not, you may be able to fashion a replacement using a cut-off chopstick, a plastic drinking straw, etc. Some machines work just as well with a stand-alone thread spool set off behind the machine. Sewists sometimes will set the thread spool inside a jar behind the machine.
Feb 09, 2017 | Brother Sewing Machines
Why doesn't it cut threads?
Could possibly be an adjustment needed in the cutting apparatus.
Nov 21, 2015 | Sewing Machines
How to replace thread cutting assembly
contact a sewing machine shop in your area ask them about the cost
Nov 14, 2015 | Brother InnovIs 4000D Computerized Sewing...
Babylock espire thread cutter stopped working
Your cutting blade is dull. It needs to be replaced by a experienced technician.
Cheers,
K
Feb 27, 2014 | Baby Lock Espire
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
Apr 06, 2008 | White Sewing Speedylock 1600 Mechanical...
Upper Knife
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
29 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
