Question about Whirlpool Washing Machines
Model no. wwq24abywf. tne bearings has packed up. I would like to know the procedure of replacing it.
2 Suggested Answers
  • 119 Answers
SOURCE: Procedure for replacing rear wheel bearings 2000 Forester
i'm assuming you don't have a hubshark,this is a tool that will alllow you to remove the bearing while the knuckle is attached to the car,you may be able to rent this tool at a auto prts store .if not you need to remove the entie knuckle,first remove the trailing arm bolt,then the lateral link bolt{long and stubborn bolt},disassemble the brake shoes and parking brake cable,abs sensor if equipped the knuckle to strut bolt{no marking necessary they are not eccentric} then you need a to use or borrow a press to remove hub and bearings good luck
Posted on Jul 26, 2009
I replaced driver side front wheel bearings, but starting to hear squeaks. Is this a lack of packing grease?
Dan, squeaking could be from improperly packed bearing or hub nut not tightened properly. Did you replace the races also.
Check the attached links, They will answer a lot for you.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Wheel Bearings Step by Step
Pack Wheel Bearings 1994 Ford F150 2WD Pickup Part 5
How To Install Replace Front Brakes 93 97 Ford Ranger 2WD 1AAuto com
Replacing Rotors with Tapered Roller Bearings EricTheCarGuy
Mar 12, 2016 | 1990 Ford Econoline
How big of a job is it to pull both front axles out to replace u joints do u have to drop tne bottom ball joints
Jeep actual made this pretty easy to do.
Remove the caliper and rotor.
Remove the axle nut.
Remove the three bolts that secure the wheel bearing to the knuckle.
Remove the wheel bearing.
The axle will slide out the opening of the knuckle that the wheel bearing sits in.
May 04, 2011 | 1997 Jeep Grand Cherokee
Squeaks when it's in motion now after 13 yrs of service. Like to know if I can use an machine lublicant on tne shaft of a motor.
Yes you can. I would suggest ordering and replacing the rear bearing assembly. it's a common issue on this particular dryer
Apr 22, 2011 | Frigidaire Dryers
What is needed to remedy right hand front wheel bearing play on a 1990 d21 4X4 ute
replace the bearing or wheel hub assembly.
REMOVAL & INSTALLATION 2wd Models NOTE: Refer to wheel bearing service and bearing preload adjustment procedures found in Section 1.
  1. Raise the front of the truck and support it with safety stands. Remove the wheels.
  2. Remove the brake caliper and suspend it with wire, out of the way. Remove the caliper torque plate if equipped.
  3. Remove the dust cap and then remove the cotter pin, lock washer (if equipped) nut lock and nut.
  4. Pull the hub/disc assembly off the spindle with the outer bearing. Don't let the bearing fall out.
  5. Pry the inner oil seal out and remove the inner bearing. To install:
  6. Clean and inspect the bearings and outer races.
  7. Using a brass drift and a hammer, drive out the bearing outer race. Press a new one into position.
  8. Pack the bearings with grease until it oozes out the other side. Coat the inside of the hub and cap with grease.
  9. Position the inner bearing into the hub, coat the oil seal with grease and press it into the hub.
  10. Press the hub assembly onto the spindle and install the outer bearing and thrust washer.
  11. Install the hub nut. Turn the hub a few times to seat the bearings and then loosen the nut until there is 0mm axial play. Using a spring tension gauge, check that the preload (with new grease seal installed) is 2.2–6.4 lbs. (9.8–28.4N)
  12. Install the lock-nut, new cotter pin and hub grease cap.
  13. Install the brake torque plate. Install the brake caliper.
  14. Install the wheels and lower the truck.
4wd Models The hub and bearing service procedures for a 4wd models are basically the same as those for a 2wd version, with the exception of removing the free running hub assembly and the bearing preload adjustment. Refer to Sections 1 and 7 for additional information. Adjust the preload after the wheel bearing is replaced or the front axle assembly is reassembled. BEARING PRELOAD ADJUSTMENT
  1. Thoroughly clean all parts and pack the wheel bearings.
  2. Apply grease to threaded portions of the spindle, grease seal lip and wheel hub.
  3. Tighten the wheel bearing lock-nut with a socket and torque wrench to 58–72 ft. lbs. (78–98 Nm).
  4. Rotate the hub in both directions a few times to seat the bearings. Loosen wheel bearing lock-nut.
  5. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm).
  6. Turn wheel hub several times in both directions.
  7. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm). Fig. 1: Exploded view of the front axle assembly — 2wd models 86718030.gif
    Fig. 2: Removing the bearing outer races 86718032.gif
    Fig. 3: Packing the wheel bearing with grease 86718033.gif
    Fig. 4: Pack the lip cavity of grease seal with grease 86718034.gif
    Fig. 5: Exploded view of the front axle assembly — 4wd models 86718031.gif
  8. Measure wheel bearing axial end-play. The wheel bearing end-play specification is 0.
  9. Install lock washer by tightening the lock-nut within 15–30 degrees.
  10. Turn wheel hub several times in both directions. Wheel bearing should be seated correctly.
  11. If necessary, measure wheel bearing preload. NOTE: Measure wheel bearing preload with a spring-type gauge; measure at wheel hub bolt, with tire removed. The hub assembly should rotate with 1.6–4.7 lbs. (0.73–2.13 kg) of pressure.
Jul 28, 2010 | 1991 Nissan Pickup
My toshiba tecra 8200 will not turn on when i hit the power butto tne green power light changes to a flashing yellow and stays that way
the power pack or the battery needs to be replaced
chrck the out put of the power pack with a volt meter to see if the output is fine
if so replace the battery
Radio Shack will test the power pack for you if you can not
Jun 27, 2010 | Toshiba Tecra 8200 Notebook
Directions replace front wheel bearings on a 1985 nissan stanza?
NOTE: After the wheel bearings have been removed or replaced or the front axle has been reassembled be sure to adjust wheel bearing preload. Refer to the Adjustment service procedure below. On the 1989–92 240SX there is just one wheel bearing, pressed into the hub and no adjusting cap. Refer to the exploded views of the Front Axle Hub Assembly. Review the complete service procedure.
  1. Raise and support the vehicle safely.
  2. Remove the front wheels and the brake caliper assemblies. NOTE: Brake hoses do not need to be disconnected from the brake caliper assemblies. Make sure the brake hoses are secure and do not let caliper assemblies hang unsupported from the vehicle.
  3. Work off center hub cap by using thin tool. If necessary tap around it with a soft hammer while removing.
  4. Pry off cotter pin and take out adjusting cap and wheel bearing lock nut.
  5. Remove wheel hub with disc brake rotor from spindle with bearings installed. Remove the outer bearing from the hub.
  6. Remove inner bearing and grease seal from hub using long brass drift pin or equivalent.
  7. If it is necessary to replace the bearing outer races, drive them out of the hub with a brass drift pin and mallet.
  8. Install the outer bearing race with a tool (KV401021S0 special tool number) until it seats in the hub flush. NOTE: Place a large glob of grease into the palm of one hand and push the bearing through it with a sliding motion. The grease must be forced through the side of the bearing and in between each roller. Continue until the grease begins to ooze out the other side through the gaps between the rollers. The bearing must be completely packed with grease.
  9. Pack each wheel bearing with high temperature wheel bearing grease. Pack hub and hub cap with the recommended wheel bearing grease up to shaded portions. Refer to the illustration.
  10. Install the inner bearing and grease seal in the proper position in the hub.
  11. Install the wheel hub with disc brake rotor to the spindle.
  12. Install the outer wheel bearing, lock washer, wheel bearing lock nut, adjusting cap, cotter pin (always use a new cotter pin and O-ring for installation after adjustment), spread cotter pin then install the O-ring and dust cap.
  13. Install the brake caliper assemblies and bleed brakes if necessary. Install the front wheels.
Jun 23, 2009 | 1985 Nissan Stanza
Packing front wheel bearings
what I do is put a glob of grease in the palm of my hand and push bearing down in to grease untill you see the grease come out of the bearing or you can go to your local parts store and get a bearing grease packer. also wipe spindal with a genorus glob and put grease in between bearing in rotor. To get to the bearings all you need to do is remove tire, center cap (outter grease seal) the silver cap in the center. the cotter pin, Nut, washer outter bearing then the rotor will slip off inner bearing is in rotor still being held in by inner grease seal take seal off replace with new one pack your bearings and reverse removal procedure when retightening nut do not make tight just snug the go another turn if you go to tight you will burn your bearings real fast.
Apr 07, 2009 | 2002 Ford F250 Super Duty SuperCab
2002 Kia Rio rear wheel bearing passenger side
I'm from the United States, East coast.
Nov 24, 2008 | 2003 Kia Rio
Washing Machines Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
