Question about Dell Inspiron 1525 Notebook
Screen doesn't work, when it does turn on it fades and I can't see it? Might be screen inverter? or lamp blown?
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Posted on Sep 18, 2010
Help
Check its back light inverter board and back-light CCFL lamps.
May 21, 2013 | Element Electronics Televison & Video
My HP vs17X monitor is around 4 years old. Screen is black. When I turn it off, then on again it lights for a few seconds then fades to black. The blue light on the power button is on (not flashing), but...
It can be 12vdc power supply section with bad cap, that will be the first place to look, or it is the backight inverter circuits, worst case will be the lamp assemblies, but find out first if the caps are good or bad, please note that bad cap may look normal but can have high ESR.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Sep 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My Acer Aspire One screen is faded. How do i correct this error?
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
Fade display problem
Sep 10, 2010 | Acer TravelMate 2300 Notebook
The screen syncmaster 940b comes on momentarily and the fades out, if you turn the screen off then on it does the same thing.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 10, 2010 | Samsung SyncMaster 940BE 19" LCD Monitor
Hey I have a viewsonic VX2245WM and my problem is that when I turn my computer on the monitor light goes red-ish like a red light that is starting to fade away and the screen is completely black like its...
Almost the same chassis as VX2235.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | ViewSonic VX2245WM LCD Monitor
Monitor on a emachine 250 computer comes on picture is very light faded in the background but no light
This is a typical symptom of a failing LCD screen inverter board or LCD screen backlight lamp. The backlight lamp failure symptoms are very similar to the inverter board failure symptoms. If you have to guess which one is causing the problem, try replacing the inverter board first. LCD screen inverter boards fail more often than the LCD screen backlight lamps.
Feb 16, 2010 | Acer Computers & Internet
My 72hm195 color fades then picture jumps now i
Ur LCD inverter board it dead,U replaced this board to get picture back.It usally aa long board.
Jan 27, 2010 | Toshiba 72HM195 72" HDTV
Black screen
If it fades linearly, it is probably the high voltage inverter for the backlight fluorescent lamp. Generally, the lamp dies over time with some flickering of it first.
That inverter is normally on a small, separate board and once the unit is open, it is easy to locate and replace.
Sep 30, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 25, 2009 | Acer Aspire One PC Notebook
Dell Inspiron 1525 Notebook Logo
141 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
