Question about Xerox Phaser 6100/BD Laser Printer
My xerox is displaying "mpt legal empty". What does that mean?
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
Black Smudges from Tray 1 MPT
Dust, dirt, toner, in paper path, clean. -Carl
Apr 17, 2014 | Xerox Phaser 7700 7750 color laser printer...
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
Trying to install a new mpt (shootout) assembly for the xerox phaser 6350. Is there a manual/diagram somewhere that I can refer to? Thanks!
Here is a link to the complete service manual for the xerox phaser 6350 it has full diagrams and step by step detailed instructions for every part of the printer
http://www.scribd.com/doc/42787465/XEROX-Phaser-6300-6350-6360-Parts-List-Service-Manual
Hope this helps
Mar 23, 2010 | Xerox Phaser 6350DP Laser Printer
Xerox phaser 7760 sends fault error code 007-274. Won't go further. -john
This error means there is an open circuit in the Paper size sensor, in Tray 1/MPT.
It could be a broken wire in the tray assembly, or a fault on the Engine control interface board.
The voltage at the sensor should be about 3 VDC. (Pin 1 of Plug J610)
Dec 22, 2009 | Office Equipment & Supplies
What to push when using legal paper
Load the paper between the guides on the MPT tray push the guides up to the edges (otherwise pressing the blue button won't work) then press the blue button on the right hand side of the paper. QED.
Oct 06, 2008 | OKI C5200n Laser Printer
Xerox Phaser 7300
Check in side the fuser unit there are two latches to release it and the unit comes out as one. check in there also you may have a paper feeding issue try to use the MPT as the paper sourse.
Sep 26, 2008 | Xerox Phaser 7300DN Laser Printer
Printing legal documents
Absolutely. Just click on the "PROPERTIES" button found on the "PRINT"menu. Find the "PAPER SOURCE" option, open it and select "Manual Paper Tray" or "Manual MPT". As soon as you confirm your print job, you unit will display a message asking for paper on the manual tray, which is the horizontal slot just above the paper tray. Insert each legal paper manually until your print job is done.
Oct 30, 2007 | Samsung SCX-4016 Laser Printer
Xerox Phaser 6100/BD Laser Printer Logo
89 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
