Question about Estate TEDS840JQ Electric Dryer
How do you disconnect the door plug? - Estate TEDS840JQ Electric Dryer
  • Estate Master
  • 8,220 Answers
Use a small flat blade screwdriver.
Posted on Sep 10, 2010
  • Dan Webster
    Dan Webster Sep 10, 2010
    This video of a newer dryer being broke down shows how the guys disconnects them pesky quick connectors. LOL
  • Dan Webster
    I have a page shows how to get into yours HERE
How do i remove the rear door panel on a 2005 pontiac grand prix
  • Instructions
      • 1Roll the door window all the way up. Disconnect the car battery's negative cable with a wrench.
      • 2. Remove all cover plugs on the interior door panel with a putty knife. Remove all armrests, door pulls, the window crank and trim-panel retaining screws with a screwdriver.3. Remove and disconnect any electrical devices in the door panel. Pry the controls out with a putty knife, and unplug the wires.
  • 4. Pry the trim-panel clips loose with the putty knife. Do not pry on the panel between the clips, or the panel could be damaged. Separate the trim panel from the door slightly, and disconnect the courtesy light. Remove the panel from the door.
  • Sep 12, 2012 | 2005 Pontiac Grand Prix
    Dl F code
    Code F/DL - Door Will Not Lock
    This is a very common problem with Whirlpool duet front-loading washers. The first thing you need to do is to make sure the door is closed all the way. Clear the code by clearing the control. Then restart the washer and shortly after you should hear clicks coming from the washer. This is the washer attempting to lock the door and will do so 6 times before displaying the code. After you hear the clicks, pull on the door to see if the door is locked or not.
    If the door isn't locked remove the top off the washer. Once done you should see the main control or CCU as Whirlpool calls it. On that control you should see 10 plugs on the front lip of the control. Counting from left to right the sixth plug is the door solenoid plug. Make sure that plug is connected on the board good. Also make sure that plug 8 is connected well, in fact make sure all of them are connected but these are the ones that will cause this problem. After doing this clear the display and attempt to use the washer again. If the washer works after doing this I recommend using tie straps to hold the plugs in place. I do this by wrapping two tie straps around the entire control the long way so that one strap holds all the bottom plugs in and the other holds the top plugs in. Note that one tie strap typically isn't long enough to wrap around the control so you may have to connect two together. Also look down in the washer and make sure the wires on the door latch are plugged in good.
    Once you are done plugging in the wires good try the washer again. If it still doesn't work you need to test ohms across the door lock solenoid coils. To check this, first disconnect power from the washer. Then disconnect the plug that connects to the solenoid coils which is the sixth plug from the left. The plug should have three wires. The wire on the far left is common. This means that both solenoid coils connect to that terminal. Using your ohmmeter, check ohms from the far left wire to each of the other wires. There should be approximately 60 ohms to each wire. If not, replace the door latch. If the coils check ok it is possible the door latch can still be the problem but it is likely the main control (CCU).
    If the door is locking but you are still getting the F/DL code you need to check the door switches. To check this, disconnect the power from the washer. Then disconnect the plug that connects to the door switches, which is the eighth plug from the left. That plug has four wires. Check ohms between the two wires on the left and the two wires on the right. With the door locked the ohm reading should be near 0 ohms between each of the wires. Note that if the door isn't locked, clear the code and start the washer and as soon as the door locks unplug the washer. If one or both of the switches are open (electrically) replace the door lock. If the door is locking and both of the switches check good (pass the ohms test) replace the main control (CCU).
    If the door wont unlock to get at the latch, take the bottom panel off with the 3 screws along the very bottom of the machine. You can pull on a manual release that is at the bottom of the door latch.
    Hope helps.
    Jul 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Thow to take off door pannel and install passenger side window motor on 2000 jeep grand cherokee
    first you have to remove dead plugs on door handle and remove screws another screw on door opening handle and you have to disconnect 2 metal pins behind that and look all around the door panel sides and under should have several rivets make sure no any screw and rivets left on door panel pull door panel foward and pull it up dont go too hard dont damage door panel conections for proper reinstallation. before removing door panel from the door dont forget disconnect cable connections from window and door lock switches.good luck
    May 07, 2011 | 2000 Jeep Cherokee
    Our automatic ice dispenser hums but doesn't move ice through to be dispensed
    Resolving the frost in shoot problem .
    Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
    Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
    In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
    Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
    Jul 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ice and water
    Remove the top hinge cover on the freezer door and disconnect the plug there . This removes power to the freezer door . Remove the dispensor drip pan and the 2 screws holding the dispensor cover on . Disconnect the plug from the cover . You should now see a circuit board only held on by plastic clips , a disconnect plug on the left side and on the right , 1 or 2 wire terminals . This board is what you need to replace . When getting a replacement , take your complete model number so you get the correct board .
    May 26, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
    Need to remove inside door panel on drivers side 1999 chevy silverado z-71 3 door new body style
    just pop out the triangle piece from the top at the top front of the door panel with a flat head screwdriver. Then simply pop out the door lock cover from the aft side and the door handle cover from the aft side as well. Then pop up your cap containing the auto door locks and windows and disconnect the cannon plugs. Then just remove 2 screws (1 from under the door lock/window cap and one just insde the door handle itself. You'll then life up and towards you to remove the panel. Don't pull it too far out because you'll still need to disconnect the speaker cannon plug and pull out the door open light at the bottom aft of the panel. You can then set the door panel off to the side.
    Jan 19, 2010 | 1999 Chevrolet Silverado 1500
    The ice maker door stands open by about a quarter of an inch allowing cold to escape and frost to form. How can I replace or repair the little ice dispenser door on the front of my freezer section?
    Remove the top hinge cover of the freezer door and disconnect the plug . This removes power to the dispensor . Pry the bottom of the control board outward and disconnect the 3 plugs on the board . Remove the 4 screws holding the dispensor switch housing and slide out . The door flap solenoid is the probable problem . Remove this piece ( upper right ) by removing the 3 screws . Replace with part number WR62X10055 . Reinstall in reverse .
    Sep 25, 2009 | GE Refrigerators
    My Whirlpool Duet washer showed F22 error; we followed manual instructions; disconnecting power, etc. but door remains locked and washing cycle won't restart. Help!
    If Pause/Cancel does not work:
    1. Unplug the washer or disconnect the power for one minute.
    2. Plug in the washer or reconnect the power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
    Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Estate TEDS840JQ Electric Dryer Logo
    26 people viewed this question
    Top Estate Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Terry Schneider
    Are you an Estate Dryer Expert? Answer questions, earn points and help others
