Question about Linksys Wireless-G WRT54G Router
Firmware upgrade was interrupted & now I can't connect to it. I have reset it 3 times & still nothing
  • Linksys Master
  • 7,733 Answers
TRY
Upgrading the router's firmware will give it numerous functions. This includes a more stable connection to the internet.
To upgrade the router's firmware, complete the following steps:
i. Downloading the Firmware
ii. Backing-Up the Router's Settings
iii. Upgrading the Router's Firmware
iv. Completing the Firmware Upgrade
v. Restoring the Router's Settings
vi. Completing the Firmware Upgrade Process
NOTE: Before proceeding with the upgrade, your computer must have an active Internet connection. It is also recommended that you use a wired computer in upgrading the router's firmware.
Posted on Oct 29, 2010
Device drivers and firmware upgradeable. Firmware accidentally interrupted. Now USB device is listed as unknown. How to reset the device? (motic2500)
Once a firmware download is interrupted, the camera usually becomes a useless "brick". You'll have to contact the support section of the manufacturer's website for instructions.
Aug 23, 2011 | Cameras
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
My linksys a + g wrt55ag wireless router is having problems : It keeps restarting on its own every few seconds. ( lights go on then after like 2-3 sec it restarts and does it all over. I tried reseting it...
Try to upgrade the firmware of the router.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
Oct 05, 2010 | Linksys A+G WRT55AG Wireless Router
Hi, my netgear rangemax wpn824 v2's firmware update was intrpted by power surge. now i can't access router, how can i solve that issue. thanks
Hi
As i can see that you have mentioned that the firmware upgrade was interrupted & now u can not access the router. Now you can try the following troubleshooting steps
1) press in the reset hole on the back of the router for 10-15 secs.
If it doesn't work
2) press in the reset hole for 10 secs & while pressing the hole take the power cable out, while still pressing the whole put the power cable back in &release the hole.
3) turn off the router for 1-2 mins & then turn it on.....& if the same problem persists that means that the router has gone faulty. You have to buy a new router or get it replaced from NETGEAR.
Thank You
Jan 03, 2010 | NetGear RangeMax NEXT WNR854T Wireless...
Keep losing connectivity
What kind of adapter do you have? I was so sick of resetting the thing daily, that I just went and bought another router.
Linksys wireless router has many bugs: connection issues like no connection or constantly having to reset the router. It isn't compatible with many network adapters2.gif. Hope this helps!
Sep 19, 2009 | Linksys Wireless-G WRT54G Router
When I disconect the player from the charger I get the following message "Connect to PC and use device manager to repair" then shuts down. After connecting to device manager it tells me the device is...
Hi there !!
This is because of the old firmware you are using in the player. Go to link below to download the latest firmware 3. & everything will get back to normal.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&sct=FLASH_AUDIO_PLAYERS_SU&cat=MP3_PLAYERS_CA&grp=PORTABLE_ENTERTAINMENT_GR&session=20090908093859_59.164.5.137&ctn=SA261/17&ds=SA261/17&mid=Link_Software&hlt=Link_Software
Here's the instructions, how to update firmware in the music player:
Software/driver information
Firmware upgrade readme file - GoGear Digital AudioPlayer SA261 , SA260, SA255, SA250
Firmware (FW) version 3.0 + Philips driver for WindowsMedia Player
Benefits
By upgrading you will gain access to the followingenhanced functionalities:
- Solving the problem with occasional hang up afterfirmware upgrade.
- Adding of a Help file in Device Manager that user maycall up the file by pressing F1.
Do I need the software?
- Press the MENU key
- Scroll down to Settings
- Enter Settings by pressing the > key
- Scroll down to Information
- Enter Information by pressing the > key
- You will see FW Vers: xxx, where xxx is the version
- If you already have the latest version, there is noneed to upgrade.
Compatibility
Please make sure that your PC is running on one of thefollowing operating systems to perform the upgrade
- Windows 2000 �V SP4 (or above)
http://www.microsoft.com/windows2000/downloads/servicepacks/sp4/default.asp
- Windows XP (home or Professional) SP1 (or above)
http://www.microsoft.com/windowsxp/downloads/updates/sp1/default.mspx
How to download the software to your PC
- Launch the Windows Explorer
- Enter the Philips support site at urlhttp://www.philips.com/support
- Select your resided country & language
- Enter the model number
- Click on Software under Product Support
- Double click your desired language under Firmwareupgrade software to download the firmware to your PC.
- Download the file in a temp directory on your PC.
How to upload the software to your device
- Run the SA_PKG_xxx.exe file to install the DeviceManager with the new firmware
- Connect your GoGear to the PC using the provided USBcable
- Make sure that you have a new battery inserted.
- On your PC, double-click on the Philips GoGear DigitalAudio player icon to run / start the same.
- A dialogue box will pop up; click Upgrade to start theupgrading of the firmware.
(Please do notdisconnect the device during the upgrading process as this interruption maydamage the firmware!)
- Follow all screen instructions to complete the firmwareupgrade.
- The Device Manager will close automatically once thesuccess message is displayed.
- Close all opened application and then safely removeyour GoGear micro jukebox by clicking on the eject icon in your task traybar.
When prompted,��The USB Mass Storage Device can now be safely removed from the system��,click OK and unplug your micro jukebox.
- Once the GoGear micro jukebox is disconnected from thecomputer, the display will show ��Firmware Upgrading�� for a couple of secondsand then start up as usual.
If the messagedoes not disappear after 2 minutes, do a soft reset by pressing and holding theplay key and the volume + key for a couple of seconds.
- Your GoGear firmware has been upgraded after you seethe "upgrading" message.
Note
Windows XP and Windows 2000 users: Your device will beautomatically disconnected as soon as Device Manager finishes interacting withyour device.
Regard's
Anurag Shukla
Sep 08, 2009 | Philips GoGear SA261 MP3 Player
Ipod touch repeats a song over & over I have to manually advance
linda if you have not upgraded your ipod`s firmware please do it because i was facing the same problem,i upgraded the firmware and it fixed the problem.you can upgrade the firmware using itunes and clicking on check for firmware.if the firmware is already upto date then please reload the same firmware.
take care.
Jun 13, 2009 | Apple iPod touch
Failed firmware upgrade.
Here is how to hard-reset your MDA/Wizard using a key combo - courtesy of a smart T-Mobile tech support help desk guy who wrote a note about it as it's not in official help doc's: 1. Simultaneously hold down the Communication Manager and Voice Dial buttons and put the Soft Reset 'button' with the stylus tip - all at the same time. 2. You see a very scary looking black screen with white letters in System font reading something along the lines of ?Are You Sure? Press Send key to continue.? 3. When you push the 'Send' key, the Green pick-up the phone key process starts 4. Next you will see what made me smile like a kid - Formatting FAT partition and very briefly in matter of few seconds began normal first boot.
Dec 27, 2006 | i-mate K-jam Smartphone
Linksys Wireless-G WRT54G Router Logo
703 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
