Question about Garden
Putting in gear causes it to **** forwards reverse gear works good. ???
  • 944 Answers
In general if the Reverse gear works and forward gear gets stuck it could be because the gear getting locked up while rotating in clock wise direction .The alignment of the gear tooth is having some problem.Some times you need to put some lubricating oil into the gear to make it loose to move to and fro.Please specify the brand name and model name to be more specific about where to check for the problem.So i could give you the parts diagram.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 10, 2010
Shifter moves on big bear 350 but quad wont reverse now it goes forwards
for some reason you are not getting into reverse , there is no real reason it should stay in forward gears unless there is someting wrong with the shifter itself being in the wrong position this can happen take it off and reposition it and make sure your clutch is disengauging to shift gears , will it go into all gears or just 1 forward , ck into that and be a little more specific on the problem ,good luck
Mar 18, 2014 | Grizzly Big Bear Atv Maintenance Free...
My john deere gx75 don't go into reverse and when i put forward gear i hear a noise like a tic tic tic...
It sounds like the spider gears inside transaxle is worn or broken causing noise and causing reverse not to work.
Oct 16, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
95 mustang v6 auto no forward gears but works in reverse had ****** rebuilt and same thing
Maybe your differential is shot and will only allow reverse spin or the transmission was not really rebuilt professionally. Was the transmission checked outside of your car after rebuild? Does your vehicle have a Powertrain Control Module (PCM)? Maybe the module went bad or faulty.
Jun 18, 2012 | Cars & Trucks
I have a 1990 GMC RALLY VAN 3500. When I put the van in any forward gear it seems as though the emergency brake is on. There is force on the engine as though it is trying to turn the transmission but no...
when you say you checked the rear end for problems and things appeared good did you check the rear end internally to see if there is a broken gear tooth or metal in the differential oil.i`ve one were this was the problem(a broken gear) that would get caught and stop the forward motion or make it hard to turn.i`ve also had it were the rear brakes were causing a forward motion problem like your having.the shoes were rotating so far when the drum was turning then apply and lock up until it was put in reverse.just some things to check out.if things were working good with the rear drive shaft removed and the problem starts with it in then the problem is in the back end some where as mentioned above.
May 25, 2011 | 1990 GMC Rally
I have a 1998 Oldsmobile Bravada auto trans drive works fine but no reverse
Are you sure you have all 4 forward gears? Most of the time a no reverse condition also means 1st and 3rd only.No 2nd or 4th.If you dont have all the forward gears as i suspect , the reaction shell is stripped or broken.If you do have all the forward gears then these are the two most common reasons you do not have reverse.1 reverse input clutches are damaged or burnt 2 forward cltches have slipped to the point they are welded together causing a mechanical bind in reverse and also causing the transmission to pull forward in neutral.Let me know if i can help.Good Luck.
Feb 28, 2011 | 1999 Oldsmobile Bravada
Was pushing snow and heard aloud ping while in reverse and it quit pulling.all forward gears still work. sounded like a u-joint. believe me i no that sound.i drive it like i stoled it. lol.but thats what...
not sure if this is an automatic or manual transmission 1st (automatic)if all forward gears are still working what it sounds like is that the reverse drum in the transmission has come apart. which will eventually cause the forward gears to start to go if thats the case, the rapir for the reverse drum is internal the transmission will need to be rebuilt. you can just put a reverse drum, but my opinion is there will be more damage and while its out might as well rebuild the entire transmission. you didnt mention if it was 4 wd or not and only rarely have i seen a transfer case cause the same issue, once most recently in a f150 with a manual transmission i was working on the chain stretched so bad it lost reverse but had all forward gears. 2nd (manual) could have lost the reverse synchronizer whic again the trans will need to be repaired either with just a syncro or complete rebuild. hope this helps
Feb 04, 2011 | 1999 Chevrolet 3500
The reverse gears are not working.if you put the reverse gears it will accelerate infront instead.what do i do?
It sounds like the reverse band broke. Typically with automatic transmission when you put the transmission in reverse a couple things happen. Usually, the forward clutch engages and the reverse band engages holding the reverse drum from turning, which causes the planetery gears to make the vehicle move backwards. If the band breaks there is nothing told hold that drum from turning and you have a forward gear. The bad news is the trany is going to have to come out to be repaired and usually the reverse drum is one of the first things to go into the trany, so it has to be completely disassembled. Take it to a transmission shop have them check it, hopefully it's something simpler.
Jan 24, 2010 | 2003 Toyota RAV4
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
No forward movement but reverse works fine. Help?
More than likely the forward clutches are burnt,causing the no forward movement problem.Remove the transmission dipstick and smell the fluid,if it smells like burnt coffee then you need the transmission rebuilt.
Aug 02, 2009 | Chevrolet Blazer Cars & Trucks
1990 VW cabrio wont reverse. Seems in gear but only goes forward
left and push the shifter into the floor like stabbing down ten it will go left a little more and push forward and you will be on your way in good ol R
Jul 25, 2009 | 1990 Volkswagen Cabriolet
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
