My setting always changes and i am to see manual store option .it comes few days after repair later it doesnt come till now i went 4 times to service center
  • 2,229 Answers
I'm not really sure just what settings are changing--if it's the settings on the motherboard itself (when you boot up and hit F2--or whatever--to enter setup) then it is most likely the CMOS battery on your motherboard that is weak or dead. Put a new battery in and see if that makes a difference.
Posted on Sep 10, 2010
Check light came on and drove very sluggish. Mechanic changed ignition coil as No 4 cylinder went. Then 3 days later the same. Now check light on all the time. Had AA man he said possible need injector...
try running one or two bottles of injector cleaner in fuel tank first with 1/2 o 1/4 tank of fuel then get code checked at local auto parts store some offer service for free you may call around fist to see if they do
Jan 28, 2015 | Cars & Trucks
I have a whirlpool built in oven. Model RBD275PDQ8. The display (control panel) went blank 2 months ago. I reset the breaker, nothing. Pushed buttons, it just beeps. 3 days later I pushed the upper oven...
it's the control panel behind that touchpad item. and it's not too difficult, just time consuming. My recommend is to grab a service manual online(usually around 20.00) which will provide good step by step,and also parts list.
spares? well, that's a good question. Until you have that part number, and the best way is to eyeball the one that's in side your unit(no offense to the printers, but mistakes can happen with manuals).
then you'll find out what it's like to be truly handy, eh?
May 31, 2008 | Whirlpool Kitchen Ranges
I bought the amp a few weeks ago and it worked perfectly for a couple of days and then for some reason the controlls just froze. the tap tempo light went out and the channel control light stayed the same...
Exercise your warranty IMMEDIATELY since you just bought it! If you bought this used, you LIKELY bought someone else's problem. The problem is likely in the digital effects area... probably a bad cable contact... but if under warranty DO NOT mess with it... return it for replacement or repair.
Sep 09, 2011 | Marshall Amplification Marshall MG30FX...
Took 2009 fusion sel for 4 new tires at local goodyear, when returned the front end shakes, take back still shakes, take back third time and the front doesnt shake, but the turn indicators don't work,...
sounds like you had the "new kid" working on your car. its hard to find good help these days. the service adviser should have had his better technicians look at it after the first numb skull laid hands on it. as far as the lighting problems i would say it sounds like a blown fuse or an unplugged light connector. you should have your ford dealer check it out and see if it looks like something has been tampered with. good luck. and try firestone complete autocare next time. usually better managed. usually.
Jun 10, 2011 | 2007 Ford Fusion I4 SEL Sedan
I have a Kia Spectra 2003. I have 128,000 Km's on my car. My check engine light went on 2 days ago. I went to turn my car on 24 hours later (after not driving it the day before) and my car...
It could be any number of things. Perhaps you could keep trying to get the car to run long enough for the light to come back on and check the code.
Apr 04, 2017 | 2003 Kia Spectra
My panisonic plasma tv just shuts off and red light blinks 10 times the stop then 10 times have to unpluge for bout 10 min the runs fine untill it shuts off agine normally bout 3 hrs later maybe 2 hrs. i...
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Apr 15, 2010 | Televison & Video
Armstrong furnace ultra 80sx doesnt always lite on first try,service repair man replaced smartvalve,sensor and igniter he says its ok if it doesnt always lite on the first try ,sometimes it takes three...
Sounds like your gas valve is sticking. Your repair man is somewhat correct by meaning that the furnace will attempt to start 3 times before going out on "Lock-out". The furnace is reaching it's expected life and you will start experiencing more frequent issues with it. Check into some of the incentives to get a replacement with a higher efficiency rating. The newer units have greatly improved in performance as well as comfort.
Jan 13, 2010 | Heating & Cooling
Sometimes my text messages are coming in very delayed, anywhere from 15 mins to an hour, but it doesnt happen every time. Also,sometimes when people call me my phone is not ringing and then im getting...
This is an issue, no matter what the company. Yes, they are trained to look at you that way. Till you tell them you will be changing companies....
I would dare to say that not knowing your location, it could be interference of building or other high line electrical, lack of towers, etc. Even going into certain shopping areas create delays on information. It happens here very often, and our whole community knows it. WHY does it always work when you are in church, tho!
Oct 17, 2017 | Samsung Rant Cell Phone
Voicemail picks up too soon and New voice mail message always on
Check call waiting feature with mobile provider on number of rings to voice mail. Many problems repaired with booting phone (holding on/off button down till screen logo comes on & removing charged battery cleaning contact connections on phone and battery with DRY SYnthetic NOT cotton cloth ideally clean battery with alcohol swab let dry before returning to phone
Aug 07, 2009 | Vtech DS6111 Cordless Phone
Doesnt always start, but lights, radio, AC/heat does come on.
First place to check is the battery. Old ones can push your lights , radio, etc, but the starter is the real load. . Can verify this by using jumper cables to a running vehicle and watch your machine fire right up! The reason mornings are the worst, is the battery has had the most time to discharge, and it is probably cooler outside.
Dec 23, 2008 | 2000 Oldsmobile Intrigue
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
