Question about GE Refrigerators
My side by side has a LOUD whining noise coming from behind the freezer area that lasts for up to an hour.
  • 121 Answers
This noise is most likely comming from the fan motor. The main board often causes the fan to be noisy but it could be a bad fan motor as well. http://www.appliance-repair-it.com/refrigerator-fan-motor.html
Posted on Sep 10, 2010
  • Vineyarder Sep 10, 2010
    Thanks; called GE and they agreed it's the motherboard and are sending me a new one.
Whinning noise when engine is off
Whinning Causes
The whining noise you hear coming from the power steering pump is one of three things. The first is more of a loud "hush" than a whine; this is the sound of fluid rushing through the bypass valve when you turn the wheel all the way to one side or the other. Sometimes the bypass valve malfunctions or doesn't open all the way, causing pressure to back up in the pump and cause your engine rpm to drop. The second and third causes result from cavitation -- vacuum pockets created behind the rotor's vane blades as a result of extremely high pump action -- or air in the lines.
Nov 24, 2013 | 2003 Mini Cooper
Samsung srs2028cvw fridge freezer noise
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 11, 2012 | Refrigerators
I found and fixed loud whirring noise in freezer
I m not sure what your asking . so let me try . you corrected your problem . and it's working . i think it's great. now in a couple of day's it may do it again. generaly if you have ice build up like you described . then you may have a defrost problem.if you do . then you must correct it . the heater / or timer or thermo may be out . so if the problem comes back /get me the brand & moder #.. **** hope this helped mm
Dec 17, 2009 | Kitchen Ranges
Whirpool Side by Side making loud humming noise from freezer side
I had the exact same issue last night. I would press on the back panel long enough and the noise would go away only to return this morning at 4am. I finally got up took all of the bins and shelves out and found an very large accummulation of ice at the bottom (floor) and walls of the freezer. The ice accummulation was causing the rattling of the tubes in the wall of the freezer (I don't know what you call them), but they were frozen over on one side. I found this out once I took the back wall panel off of the inside of the freezer. I also found the drain hole back there and it was frozen over solid, as well as my ice dispensing unit at the top of the freezer. This whole problem began when I turned on the ice maker 3 days ago. I used my hair dryer and hot water to clear all of the ice from both areas and now it is nice and quiet. Don't know if the acccummulation is due to some defrost switch gone haywire, but at least the rattling is gone and my freezer is back to square 1 for the time being and I saved myself a visit from the appliance guy in the meantime. Took me a total of 1 1/2 hours to do it all.
Aug 07, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire side by side fridge/freezer
Try checking the evaporator fan. The blades are just pushed on and sometimes may work itself up or down and plastic fan could be rubbing.
Apr 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Periodically throughout the day there is a loud motor noise.
you may have a fan problem or ice maker open freezer switch on the frame freezer side press it you will know were the noise comming from
Apr 06, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Whineing noise\and leak on freezer side in the bottom of it
yes the water in the bottom is because your drain tubing is cloge thid is the small hole in the frezer area defrost your fridge use a wire to clear out the debri that clogs your tubing the water should drain in the pan where the compressor is thanks from gilles
Feb 10, 2009 | GE GSS20IEP Side by Side Refrigerator
Whining noise from freezer
Fan motor is bad and needs to be replaced.
Nov 26, 2008 | Refrigerators
Refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Nov 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
258 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
