Question about AO Smith 2 HP 115/230V 56C Replacement Motor
Where can I get a manual for the ao smith sq1202 pool pump or schematics
    President:
  • AO Smith Master
  • 1,378 Answers
Try this link: http://drawings.aosmithmotors.com/sendfile.aspx?ItemNumber=SQ1202&DrawingType=OUTLINE
There is a small portion that describes the line connections. If you need the internal wiring diagram you will need to contact me thru www.arrowmotor.net and well get it from AOSmith for you.
John
Posted on Sep 10, 2010
I have a 2.5h 2 speed motor with 3 wires Black, Red, Blue & Green (Ground) My question is how do know what ones are L1 & L2 and N?
That model number is listed as a 230v motor (no neutral) The wires should be attached to terminals marked L1, L2 and A . L1 is high speed, L2 is common and A is low speed. Check the name plate for wiring information.
Feb 25, 2011 | AO Smith SQ1202 Pool Pump Motor
How difficult is it to replace the bearings on an a.o.smith sq1202 pump
Bearings MAY be bad from a bad seal. To do this right you MAY need an arbor press to insert new seal without damaging it.
Aug 05, 2009 | AO Smith SQ1202 Pool Pump Motor
How to manually reset an AO Smith 2 hp motor?
If you did not press a reset ( and even if you did) the motor is damaged and that is causing the circuit breaker to trip. You need to have the motor inspected to see if the damage is repairable or if you need a new motor. A local electric motor repair shop should be able to take care of that for you. The thermal overload has reset itself if after cooling down the motor is trying to start but trips the breaker.
To be certain it is the motor, disconnect the line leads and be sure they are insulated from ground and one another. Turn the breaker back on. It should stay closed which confirms it is the motor tripping it when connected.
If for some reason the breaker still trips, there is a problem with the electrical circuit feeding the pump.
Jul 26, 2009 | AO Smith A O Smith Motors A O Smith 2hp...
Hayward pool motor shuts off in backwash mode.
Check the pump suction filter? To backwash it, is to
open the backwash tank cleanout valve, to clear the dirt out. If this does not work, check the pipelines going to the backwash tank for clogged lines.
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
AO Smith 2 HP 115/230V 56C Replacement Motor Logo
276 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
