Question about Xerox 5665 Copier
How do I change the waste toner bottle in a Xerox Workcentre 5030
2 Suggested Answers
SOURCE: Where is the waste toner
  1. Open the Waste Toner Bottle Access Door. The door is located on the left hand side of the machine, behind the Bypass Tray.
  2. Pull the colored cap from the top of the bottle and screw the cap onto the opening of the bottle.
  3. Remove the used Waste Toner Bottle and dispose of it according to the instructions contained in the new Waste Toner Bottle box.
  4. Unpack the new bottle from its box.
  5. Install the new bottle in the machine. Make sure that the bottle is placed correctly in the machine cover.
  6. Close the Waste Toner Bottle Access Door.
Posted on May 29, 2011
Cleaned waste toner out but xerox 7545 wont ecept it says to replace waste tone
You didn't clean the bright plastic bubble at the upper inside end.
If dirty, machine thinks it is still full of toner.
Jun 24, 2014 | Xerox Workcentre 7545/PT 7545PT Color...
Hello, we have a Xerox Workcentre 7545, the waste toner cartridge needs replacing but we don't have the part yet. Can I manually empty the cartridge in the meantime so we can still use the machine? ...
If you can remove the waste toner cartridge go ahead and empty it out manually. Make sure that it is completly clean out. I use compressed air to flush out any residue.
Sep 22, 2011 | Xerox WorkCentre M-24 Color Copier
Where is the waste toner bottle on the xerox workcentre 5030 located at?
Mar 30, 2011 | Xerox WorkCentre M-24 Color Copier
Xerox work centre 7120 message say change waster toner, I found where it is but how do I change it
You can either dump out the waste toner into a garbage bag, or replace the whole toner collector. If you decide to dump it out yourself, you need to make sure that the container is extremely clean prior to reinstalling it into your copier, as sensors on the copier end detect the level of used toner by optic sensor.
-David.
Nov 03, 2010 | Xerox WorkCentre M-24 Color Copier
How do I change the waste filter on a Xerox 5030/5050?
hi, open the front door, release the drum latch,open the metallic plate next to the front door then remove the waste toner bottle
Nov 09, 2009 | Xerox WorkCentre M-24 Color Copier
Waste toner container replacement
Yes you can. But there is a window at the top of the bottle . There is a sensor that looks through that window to sense toner in it. It is a small area about a half inch high and quarter inch wide that bulged out of the top of the bottle.
Poke a hole in it, clean it with a q tip and reseal the opening you make .
That should do it.
Jul 01, 2009 | Xerox WorkCentre M-24 Color Copier
Kyocera fs-c 5030 has a terrible grinding noise in the front. could it possibly be the drum unit(black)
Take all the toner carts out and push down on the units below the toner carts. Make sure the waste bottle is pushed in firmly. More than likely, the waste system is clogged up because the waste bottle was loaded crooked.
Mar 06, 2009 | Zebra Eltron LP 2824 Thermal Printer
How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Aug 27, 2008 | Xerox DocuColor 3535 Copier
Waste Box Full/Not Installed
There is a plastic waste toner bottle. Depending on the machine it can be located in front or behind a door on back of the machine.
If you go to Xerox.com and click on support, then put in your model number, the support page, type in waste and it should show you how to change the bottle for your model.
Aug 21, 2008 | Xerox Office Equipment & Supplies
646 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
