Question about Craftsman Nailer Kit, Palm Air Driver
Paslode im 350 just cleaned it now it wont work,the led on the handle slowly blinks red/green
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
Have a paslode 350 it wont fire/ have spark, have new gas, fan works ,what could be wrong
The primary cause of a Paslode not firing is from a dirty combustion chamber. Try cleaning it with Paslode cleaner and as long as you have good fuel, good spark, and the fan works, it should fire.
May 25, 2014 | Air Tools & Compressors
Paslode 350 wont fire nail,gas new,fan works,have spark what to check next
My paslode IM350 nail gun wont spark but wen i remove the fan cover and unplug the fan it sparks nothing is loose and everything is connected but cant see what the problem is can anyone help thanks
With gun assembled but gas cell REMOVED look at LED on handle, with battery fitted LED will flash. Now press it against work piece, LED will stay lit whilst still watching LED press trigger. LED should blink off (it may blink red) this indicates that the spark unit has sent the spark. If this works it sounds like either the spark lead has been damaged and spark could be shorting across back of cylinder head or you actually have a gas problem. Check cylinder head O ring, use by date on bottom of gas cell. Depending on age of gun it may have another O ring on the sleeve (pre 2006). Check sleeve is clean do not add oil to working parts (except a smear when cleaning sleeve and around O rings when reassembling gun)
Mar 21, 2014 | Air Tools & Compressors
Epson R230 with green led and red led blinking
This is general error of the printer. When you have to change the new mother board you should be initialized it then it can be ready mode. When you try to initialization you need printer printer adjustment program. You can batter find out from google & write down EPSON Stylus R230 Printer Adjustment program or ink reseat program.
Jun 12, 2013 | Epson STYLUS R230 InkJet Photo Printer
When the trigger is pressed the light on the handle flashes green and red intermittently and nothing else happens. any ideas?
Hi,I believe that is a battery issue...either it is run down or not charging properly...
Here is a tip that I wrote about the Paslodenailers and the problems that can come up with them.
I also have a link to the Paslodemanuals which contain Paslodecleaning and troubleshooting guides.
If you need parts for your Paslode,there also is a link for a site that sells the Paslode nailer parts.
PaslodeCordless Nailer Problemsheatman101
Sep 18, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode 350 nailer wont work , push to fire fan works for 2 seconds then light flashes from green to red
Sounds like a battery contact problem or a bad battery..
heatman101
Feb 17, 2011 | Dewalt D55141FNBN HeavyDuty 16Gauge Finish...
IM350 when battery inserted flashes green then goes to red. Tried battery in other gun and works ok. Tried full charged battery (green in other gun) and led goes red in this one. Measured voltage at 6.74v....
Check the battery contacts in the gun...
heatman101
Feb 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
My paslode impulse framing nailer quit working. It fired and the fan shut of prematurely then it would not fire and the fand would not run. The blinking green LED light in the handle is blinking green...
It sounds like the contacts in the plunger are dirty or bad. Or even a wire for the contacts is loose. My guess is when you took it apart to clean it and replace the Orings you had moved the loose connection so it worked for a minute. On mine, I went all through the gun only to discover the wire feeding through the gas chamber was squished and broken inside. The wire's plastic insulation did not even have a hole in it. If you take it apart again check the wires carefully, check the contact points to make sure they are clean as well.
Another note, my father had issues with his and we went through it with a fine tooth comb. In the end we discovered it was a dirty contact in the gun where his battery hit. The battery itself was fine but once we cleaned the batteries terminals with a pencil eraser and plugged it into the gun we noticed one of the contacts had black stuff on it from the contact inside the gun. Works great every since.
Nov 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
How long is the battery goood for. Nailer won't fire. Replaced the cartridge and still nothing. I think I may need a new barttery.
I had the same problem with mine just had to take it apart and clean it. other guys that i know who use them on a day to day bases say they clean there ones once a week.
Nov 10, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framing nailer 1998 yr. model when engaged wont fire
you have spark and cleaned tool correct, but fan won't turn that freely, if so the fan motor is bad, it should come on when you pull the trigger or move the roller lever for the safety. The fan is about 80.00 Let me know if I missed something and how did you check the spark?
Jun 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Craftsman Nailer Kit, Palm Air Driver Logo
259 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
