Question about Samsung SD 616E (729507925578) Internal DVD Drive
Dear Sir, My Samsung Octo Speed Plus DVD combo drive is unable to read dvd. Please suggest what to do as i already clean its head with soft cloth but then also its light is blinking to read CD/DVD but unable to read any one. moreover i m receiving msg for CD Burning whenever i insert any DVD. Please suggest what to do??? Sunil Dutt Lal
sandrew
  • 2961 Answers
SOURCE: Combo drive CD not reading, but DVD ok
it may have dual laser and one that reads cd's is faulty, but try uninstalling the dvd drive first then re installing it to see if it cures it, if not the drive will need replacing. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers
Posted on Mar 30, 2007
jackboy
  • 2985 Answers
SOURCE: Had some problem with connecting the DVD drive to the PC
Depend on what you have in your system already. If your are replacing and existing drive simply remove it, and replace on the same IDE cable making sure the jumper is set to slave. Assuming you have one drive to the 0-IDE connector and the other connector is is to existing CD and this new drive is to be a second one. You will need another IDE ribbon cable. Set the drive to Master- connect the cale. position and fix the drive and plug the other end on the cable to the second IDE connector [Drive 01] See you mother board manual - connected a spere power connector.
Posted on May 18, 2007
sandrew
  • 2961 Answers
SOURCE: cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Posted on Aug 10, 2007
PcExpert
  • 293 Answers
SOURCE: DVD combo drive not working
Did you set your jumpers correctly? How about using a different power Cable? Different Data Cable? If all fails try diagnosing the problem. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps
Posted on Sep 23, 2007
MyTechGuru
  • 93 Answers
SOURCE: my SONY DVD RW ROM is not reading any DVD
Installing a third-party image editor or viewer applications may sometimes hijack the image file associations. In such circumstances, you could use this utility to repair the file associations (following image file types) to Windows XP defaults.
Click on Download utility and Click on RUN and then once again RUN
Check All the files and then click on Repair Associations
Download Utility
For the CD DVD Issue
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives loadTOCNode(2, 'moreinformation'); Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. On the Device Manager tab, click View Devices By Type. 4. Double-click the CDROM or DVD branch to expand it. 5. Note the properties for each device listed in the branch. To do this: a. Click a device, and then click Properties. b. Click each tab in the device properties dialog box, and then record the device information and settings. c. Click OK. 6. Click OK, and then close Control Panel. 7. Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
Posted on Aug 13, 2008
MY SUMSUNG DVD writer octo edge is not reading some CD and not reading DVD at all.
This issue is common to CD/DVD-ROMs. To fix this issue, visit my technical page at reyfrancisbasa2.blogspot.com for a graphical step-by-step instruction.
Thank you for visiting FixYa!
Apr 25, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I have a Dell Inspiron XPS M140 PC Notebook on which I'm trying to load Microsoft Office for Home and Business 2010, and I can't figure out why the installation DVD can't be read. I was only going to load...
Hello
Do any other DVD discs work with the laptop? Lets start from there.
do you get a error message or something on the screen when you try to insert the disc or run the setup?
Sep 25, 2010 | Dell Inspiron XPS M140 Notebook
I m using samsung octo edge dvd writer in nero i m unable to find write dvd option How can i write/burn dvd plz help!
To use "Burn DVD video files" in Nero, you have to switch on Advanced mode instead of standard.
In my version, this is what the bottom right corner of Nero StartSmart Essentials looks like in the two modes.
Apr 10, 2010 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I am having trouble burning to a DVD-RW,it does not recognise the disc I have in the drive,it keeps asking for a DVD-R-RW, what is the solution, thanks , Graeme
Graeme,
The LG GCC4522B CD-RW/DVD-ROM Combo Drive is NOT a DVD BURNER.
It is a "combo" drive, which means that it can only READ DVD+/- discs and READ/WRITE CD's.
There is no firmware upgrade or any other modification that can convert your combo drive to a DVD burner.
Oct 25, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Samsung dvd rw with octo edge dvd rom says burning failed for dual layer disc
I will presume that you do not have a combo DVD.
If you have a "combo" drive, it doesn't burn any DVDs.
First, has the burner ever burned dual-layer DVD's successfully?
Radio Shack has a laser cleaner ($13). Read & follow the directions. It is an audio CD with a row of brushes. No chemicals involved.
Recommendation:
Use Verbatim DVD's, they are the best. Samsung is also a top brand.
Oct 02, 2009 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Dvds wont play in dvd rom on travel mate 2480
if the icon of DVD is there but when u try to open it doesnt bring any windows gives u error unable to read the contents then ur DVD drive lens is faulty try cleaning it with a very soft cloth open ur drive tray and u will a crystal eye shiny thing just clean it by rubbing very gently with a tissue paper or very soft cloth which is used to clean lcd's or if u have a lens cleaner cd it will be best , if it doesnt work then i will suggest changing the DVD ROM drive there are plenty of cheap DVD writer drives available on ebay under 60 $ or so try them pls vote if u find me helping
Feb 23, 2009 | Acer TravelMate 2480 Notebook
POWER CALIBRATION ERROR
Power Calibration error indicates that the drive hasn't been kept clean and is unable to guarantee a good write to disc...
I recommend a wet and dry CD/DVD Cleaner disk with Alcohol on the wet side (Like Tape Head cleaner liquid) and let it dry for a minute then run the disc again... if it still happens the drive is on its way out.
May 25, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Dvd reading problem
it may be due to virus..dont try decoders..and just remove the drive and clean ur lens with an soft cloth..no need to remove from the cabint..
if u have an software isobuster then use it,nor download it's an freeware..stil it doesn solve tell me..
if it works den do rate me
ne other queries tell me...
im always der to reply..
cya..
Apr 11, 2008 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Samsung SD 616E (729507925578) Internal DVD Drive Logo
120 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
