Question about Smeg WDI12 Front Load Washer / Dryer
The water won't drain from the machine and stops mid-cycle. Showing error code 14. What does this mean? thanks Adrian
  • 11,896 Answers
E1 Water loss safety device
E2 Anti-spilling device (only outside washing program)
E4 NTC water in short circuit or interrupted
E5 No load
E6 No drain
E10 Motor overcurrent
E11 Motor control triac in short circuit or interrupted
E12 Tachometer
E13 PTC door block
E14 NTC dryer in short circuit or interrupted
E - Interface communication problem – mother board
E - Card hardware malfunctioning
NTC stands for negative temperature coefficient, the temperature sensor which is built into the heating element. These don't often go wrong but it is worthwile checking it plus the continuity of it's wiring to the module. Could well be another module failure, which are quite common on these machines.
Posted on Sep 10, 2010
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
What does half 6 E error code mean on LG washer
make sure the drain hose is higher than the back of the washer, has to be to function the draining of the unit.
Jan 02, 2015 | LG Washing Machines
I have a Bush WV 1460TVE washing machines and I have a code showing ERR 5 and stops mid cycle. What does this mean?
This is from the manual...
Err5.... CAUSES/SOLUTIONS: Water level not met in 8 minutes/Make sure that tap is turned on and water pressure is normal.(a)
C/S:Height of the drain hose is below 80 cm/Install drain hose within80-100cm of height. (b)
C/S: The drain hose is in water/make sure the drain hose is not in water. (c)
Nov 04, 2012 | Washing Machines
Stops Mid-Cycle: Error code is blinking ?H? then ?F?
FH, in mid cycle most likely your pump is blocked, hit drain/spin and see if water drains, if not clean pump
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
F-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Apr 01, 2009 | Washing Machines
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Nov 20, 2008 | LG WD-1280FHD Front Load Washer
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
Smeg WDI12 Front Load Washer / Dryer Logo
321 people viewed this question
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
