Question about Hotpoint HSS25GFP Side by Side Refrigerator
Where is there a reset button on a hotpoint frig... after having my electric off for months.. now its turned back on... its not cooling the frig and freezer lights are on.
  • 833 Answers
SOURCE: frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Posted on Jun 09, 2008
SOURCE: I have a Dometic rm2807
Check out this site www.rvcoolingunit.net
Posted on Jul 28, 2008
docjohn174
  • 943 Answers
SOURCE: Hi Guys, I have a
HI thanks for your question. the problem is either that the fan in the freezer is not working, or the fridge is frosting up, or the coils at the back of the fridge are dirty. first clean the coils .it could be you problem. thanks the appliance doc please rate my answer . thanks.
Posted on Oct 09, 2008
  • 5 Answers
SOURCE: freezer fan not running
Often times the defrost termination switch (which opens when it gets warm enough) will hold the fan off until it closes again when the freezer runs. It is possible that the switch is not closing, but be sure the freezer is getting cold enough for it to close.
You know the freezer is likely cold enough when you see frost covering the entire evaporator coil after a few hours of operation. A partial frost pattern could indicate low refrigerant, or a restriction of refrigerant.
Posted on May 29, 2009
Sea Breeze
  • 4655 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
Control panel lights not working and none of the buttons resond
Power? Has circuit breaker popped? Possible you have ground fault protected outlets and one of them popped like a circuit breaker. It usually causes all outlets on that circuit to also disconnect. They have a reset button similar to other circuit breaker devices, so double check. If it pops again, you may have a serious electrical problem or appliance problem. Unplug all appliances plugin one at a time to discover bad appliance. If none are bad and you still have frig problem. Time to call an electrician. You may be able to verify frig via extension cord from an outlet outside the kitchen. That if lights and buttons work, then you know it's the kitchen circuit problem. If not you may have a major problem with the control panel itself. Time for an appliance technician.
Feb 27, 2015 | Hotpoint Refrigerators
ALARM WONT STOP BEEPING
unplug it let it set for 5 mins then plug it back up hope this helps. if it continues then there is a problem with the frig that needs to be repaired. find out what's happening to cause the alarm. is it cooling? is it defrosting? what's up with the frig?
Aug 24, 2014 | Hotpoint Refrigerators
Hotpoint Rfa52 fridge not working. Freezer ok.
is temp or freezer control turned all the way up? set frig / freezer control in middle and wait 24 hours. do you feel cool air going in freezer from vent? if not change control as stated and see if you have air flow. control door to frig may also be broken or stuck
Jan 30, 2014 | Hotpoint RFA51 Bottom Freezer Refrigerator
We moved our magic chef frig on the deck-plugged it into an outlet with too many thing running. The breaker tripped.Not the frig light comes on but the frig does not work. Is there a reset button? If so,...
There is no reset button.
Firstly turn the fridge off at the wall switch. Wait 5 minutes then switch the power back on. If the fridge still does not start then you have a problem with either the fridge electrical circuit has a fault or the circuit board fuse has blown.
Apr 01, 2011 | Magic Chef CTB1722 Top Freezer...
After a moving to a new city, we had our Hotpoint model HSS251FMD WW refrig in storage for 4 months. When I installed it in our new house it will not cool. Is there a reset button?
flush the refrigerant by nitrogen & refile new refrigerant.every work doing by qualified technician.my be some compressor oil over com in freezer
Jan 03, 2011 | Hotpoint Refrigerators
We have a GE GTS 222C top freezer refrigerator, approx. 8 years old. The freezer works fine but the frig doesn't cool and is at the highest setting. We had to turn the electricity off for some wiring...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | GE Refrigerators
Hotpoint frig,top freezer motor runs contiunally, thermostat set in middle of temp. control. side of frig stays cool all time.[does not get warm as it used to] is defrost thermostat bad or timer?
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Jun 12, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Hotpoint freezer
The compressor needs to cool off before it will restart. Leave it unpluged for a couple hours to see if it will restart.
Apr 04, 2008 | Freezers
Hotpoint HSS25GFP Side by Side Refrigerator Logo
311 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
