Question about Brother MFC-8220 Fax
How do I set up my brother mfc-8220 fax machine to print a confirmation page after fax is sent.
checkitright
  • 1362 Answers
SOURCE: Printing extra blank pages
need to go in the menu and change setting
http://www.retrevo.com/s/Brother-MFC-8220-Multifunction-Printers-review-manual/id/260ag204/t/1-2/
Posted on Jan 24, 2008
SOURCE: Fax does not print a confirmation page.
Use Function 8 not 6 and use set to lock it in. Lawrence
Posted on Sep 04, 2008
cene765
  • 787 Answers
SOURCE: How I clean Drum of Brother MFC 8220 Fax machine
If you mean drum reset
1. Open the front cover, and then press Clear/Back.
2. Press 1 to reset.
Posted on Oct 28, 2009
  • 159 Answers
SOURCE: I have a Brother MFC 8220 incoming fax problem
Here are a few possibilities:
Does it still say "FAX" on the display? If it says "TEL" it won't answer the phone. Changing it is just a matter of pressing the MODE button, which cycles through four settings. FAX is for dedicated fax lines. If you share the line with a phone, check your manual for info about the other two settings.
In your menu settings is a place where you can set the number of rings before answering. If it's set too high, the sending machine will give up while your machine is still waiting for that 9th ring. I know you wrote that nobody's messed with it, but it's worth checking.
A glitch in the memory may be disabling reception. We can reset it in the Maintenance Mode:
From the Ready state, press these buttons in rapid succession:
Menu
* [the star on the phone dial]
6
If you did all that in under 2 seconds, the display will show MAINTENANCE. If you were too slow, you'll just be in the menus somewhere. Press Stop and try it again. You have to ignore all the error beeps while you do this; it's designed to be nearly impossible to do accidentally.
Once you have MAINTENANCE on the display, simply touch 91 and wait. The machine will clear all its memory, except your stored phone numbers. In a few seconds it will return to MAINTENANCE. Press 99 to exit the mode. The machine will go through it's entire start-up, as if you'd just plugged it in.
You don't need to use another fax for initial testing. Call it from another phone - even a cellphone - and see if it answers. If it squeals horribly in your ear, you've probably fixed it. Now try faxing to it.
If that function 91 didn't help, try something harsher. Go through the same routine above to enter Maintenance Mode, then, instead of touching 91, touch 01. That will clear all memory to the sate where it was when you first unboxed it.
If nothing above helps, it almost certainly needs a new Main Board. Replacing that on a non-warranty machine may not be worth it, but use Brother's website to find your nearest servicer and find out.
Posted on Jan 27, 2010
  • 1218 Answers
SOURCE: Brothers fax MFC-8220
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock.
http://www.fixya.com/support/t5660619-7a_error
Posted on Sep 22, 2010
How to program brother mfc 8460n to print confirmation sheets for when a fax is sent.thanks
Press 'Menu', '2', '4', '1'. Report Setting is displayed. Press down arrow to select "on + image". Press 'OK'. Press 'Stop/Exit'. Reference page 70 in this link to MFC 8460n on the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_8460N_8660DN_8670DN_8860DN_8870DW_EN_1586.PDF
Nov 04, 2009 | Canon LaserClass 9000L Plain Paper Fax
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " http://download.cnet.com/Brother-MFC-8220-USB/3000-2118_4-65318.html ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
note:
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Jul 15, 2009 | Brother MFC-8220 Fax
Printing report on received faxes
Fax machines usually only store the last 50 transactions
Aug 05, 2008 | Brother MFC-8220 Fax
Confirmation sheet
Scroll through your menus and look for TX CONFIRMATION set it for incomplete only or never
Jul 16, 2008 | Brother MFC-8220 Fax
Need to clear the memory of Brother MFC-8220 fax
The easy way to reset the machine is to power it off for a period of time. Say overnight will allow the battery back up on the board to run out and the machine to loose its memory.
Feb 18, 2008 | Brother MFC-8220 Fax
Finding a fax confirmation in memory
you can get a prinout of last certain faxes received or sent(appx 20), if the number is among them, it's your luck happy faxing omnipresent
Sep 20, 2007 | Brother MFC-8220 Fax
Brother MFC-8220 Fax Logo
149 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
