Question about Mitsubishi MS-A09WA Split System Air Conditioner
When I connect my SAMSUNG SH12VA1 - ­ power inverter outdoor and indoor unit say that the connection is abnormal what do I have to do to fix it?
notsomot
  • 67 Answers
SOURCE: Fujitsu AOT30PMAL inverter outdoor unit not working
Sounds like your compressor is seized or a start fault. If the unit is under five years old it should be under warranty. Call Fujitsu warranty out to have a look at it for you.
Contact details as follows
http://www.fujitsugeneral.com.au/contact.php
Sorry but either way I think your going to need a part there is very little that I can do unless your in WA.
Hope this helps
Posted on Jan 11, 2009
SOURCE: DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Posted on Apr 22, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
  • 4090 Answers
SOURCE: LG split (3 indoor) LMU360CE
02 Indoor In-Piping Error 2 times OFF
There is a complete guikde to problems on page 66 of users manual. If you dont have one get back to me with your email.
Posted on Aug 02, 2009
  • 34 Answers
SOURCE: mitsubishi mr slim mn PUL18EK outdoor, PL18FK2
8 flash is a pipe temperature error.
Posted on Aug 13, 2009
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
A/C Unit SAMSUNG -Outdoor unit model= MH080FXCA 4A was connected to 3 indoor units:
It's possible you have a bad data wire on one of the systems. Swap the data wire or both if two with a different wire. (1&4--2&3) whatever. Whatever you do inside obviously do outside. Might have extra resistamce that is throwing the error but will be fine for a ground wire.Or do one system at a time, being sure to change your dip switch settings until you figure out the problem unit. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 19, 2017 | Samsung Heating & Cooling
When we put on the air conditioner it shows F1 or ERROR on the window. What is the problem?
Hi Charity, F1 is a communication fault, I hope this helps......... CHEERS..
1?Check whether the connection of the outdoor unit and indoor unit is one to one, otherwise connect the L, N and communication line of the indoor unit and outdoor unit one to one.
2?Measure whether the voltage between the zero line and the communication line is 18V-30AC half-wave signal, check whether the communication circuit on the indoor and outdoor electric control board has been damaged, otherwise replace it.
3?Check whether the LED on the outdoor power board has been on, otherwise replace the electric control board.
4?Check whether the unit is abnormal caused by the external interference, if it is, then find the interfering source, and removes it.
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
May 10, 2016 | grunaire GSI241HXB / GSU241HXB 24,000 BTU...
How to solve u4 alarm in daikin inverter 24000btu unit
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Feb 08, 2011 | Heating & Cooling
What does error code p8 mean
P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Hope, helpful.
Feb 03, 2011 | Mitsubishi Heating & Cooling
We have a P8? CAN'T FIND MANAUL
P8-Abnormality in outdoor unit.
1.Wrong wiring of indoor/outdoor
connecting wire.......................Check the indoor/outdoor connecting wire.
2) Reversed phase......Change the connection of electric wiring.
3) Protection device is working........ Check the protection device.(LP,HP)
4) Damaged outdoor coil thermistor.....Measure the resistance of the outdoor coil thermistor.If the resistance is normal, replace the outdoor controller board.
5) Check out door coil is cleaned. If not do it.
thanks.
Jan 30, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi electric Mr Slimair conditioning. It runs a few minutes in cool mode, then it stops and an error of P8 code appears. When it runs, the fan is not strong.
connecting wire
2) Reversed phase
Solution:
Hope,it's helpful.
Jan 15, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
U4 System transmission between indoor and outdoor units Daikin
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Outdoor unit fan always runs even when indoor unit is off. I have disconnected all control wires from the headunit (at the outdoor end to rule out faulty signalling). The fan runs all the time, with just...
I have had this problem with a Fujitsu unit before. If the power is supplied to the outdoor unit first but unit is meant to have power supplied to indoor unit first, outdoor will only stop when power is cut off! In that case, you will have to run the power cable to the indoor unit first and then connect from appropriate terminal back to outdoor unit. (Often the indoor will stop outdoor unit by just cutting the power to it via use of a relay on the pcb.)
Jan 16, 2010 | Panasonic Heating & Cooling
New installation
Check the power to the door switch and make sure the door around the fan motor is on tight. and pushed in.
Aug 05, 2008 | Samsung AS18A6RB Air Conditioner
Mitsubishi MS-A09WA Split System Air Conditioner Logo
100 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
