Question about Amphion Mediaworks S99 DVD Player
Hello, My AMU DVD player is an S99 model. Any time a DVD disk is put in, the screen reads "no disk." How can I solve this problem? Thanks, Walter
  • 11,896 Answers
There a few things you can try. First is to open the disc tray. Blow really hard inside about 3 times. This will clean the dust of the laser lens.
Or use a can of air duster which will blow the dust off.
Or remove the top of the player, clean the laser eye lens with rubbing alcohol and a cotton swab.
Cleaning usually helps and solves the issue. If it did not help, you may have a faulty laser lens circuit or bad circuit board. The circuit can be tested with a multimeter
Posted on Sep 10, 2010
I need code to program a GE remote to work with a amw DVD player
If it is a AMW model 99 Sanyo DVD codes will work for it.
Dec 14, 2012 | Amphion Mediaworks S99 DVD Player
DVD won't play
Netflix doesn't know what they're talking about. I looked it up - your DVD player doesn't have an autoplay feature. Can you try the DVD on another DVD player. Computers DVD drives generally read them differently - and decode them differently, than a regular DVD player. Also, if your DVD drive is a writable drive, it will have a stronger laser than your DVD player. I think it's likely the disk is damaged, slightly. If you cleaned your DVD's laser, it might be able to read it well enough to play - or it might not. I started having problems like this with a few of my own DVDs before my DVD player's laser went out. Basically it's a combination of laser quality and disc quality. If it remains just this one disk, I'd suggest leaving it alone. But if you start running into this problem on other disks as well, you'll probably want to have the laser replaced in your DVD player.
Aug 14, 2007 | Amphion Mediaworks S99 DVD Player
Hi, my philips dvd player model number dvp3360/05 has stopped reading disks. Wjen it loads a disk instead of going to the start screen it just goes blank and on the LED display it says title. Any ideas on...
There are several reasons why your DVD player would stop reading discs.
1. Bad or dirty lens
2. Bad disc spinner motor
3. Busted capacitors on the mailboard
If you can open up your DVD player. Try to check for these problems.
Mar 14, 2010 | Televison & Video
Durabrand portable dvd player motor spin but disk not playing
I have the same problem, the this dvd player i use one time
Nov 17, 2008 | Durabrand DUR7 Portable DVD Player
Dvd player reads no disk
Hello thank you for choosing FixYa.com for your answer My name is David.
It sounds to me like Its in need of cleaning the dvd lenses collect dust over time
of no use and will cause them to not read properly try running a dvd cleaner disk in it you may have to run it a few times but it should work if it doesnt you can try to take it apart to get to the lense and clean it with alcohol and a cue tip lightly dipped.
Nov 07, 2008 | Jwin JD-VD509
DVD Player Error Message
I have this problem.. I put in a DVD that I know it has read ok before. But, now it takes a long time trying to load and then it just stops trying and returns 'NO DISK" So, I opened it up and watched it try to load. The motor on the DVD drive was struggling and couldnt keep the disk spinning a the correct speeds. Now, I am looking for a drive replacement. I hope this helps.
Oct 20, 2008 | Philips HTS3400/37 System
Not repsonding when closed
Every time I close my Coby TFDVD5000 Portable DVD Player I whait untill it is finished loading but then it says no disk. I took the back off to look at it, and I noticed that each time i close it the disk will spin untill the lens starts reading the disk. The problems started when i put a disk cleaner in, and i gess the lens was not dirty. Can you help me?
Jun 07, 2008 | Coby TFDVD5000 Portable DVD Player
Remote for DVD S99
I have great news for you.  Yes, there is a universal remote and it will operate the S99 and (I suspect) any other product you have.  I have been buying 'universal' remotes for more than 15 years and have NEVER found one to work until this one.  Logitech Hamony Universal Remote.  I had a $50 off coupon for Costco where it was sold for $100 (so I got it for $50).  My wife is so excited she can hardly stand it.  With 4 remotes in each room, she is clueless about how to watch TV again after it has been setup to watch something else.  But, with the new remote (all others have been stored away), she has all she needs.
No, I don't work for Logitech.  I just stumbled upon this and thought, what the heck, for $50 I'll try it and if it doesn't work I'll return it.  But it works!!!
Apr 02, 2008 | Amphion Mediaworks S99 DVD Player
Wrong region
i used this same procedure^on a different model. The number is entered via remote control pointing to the unit. after entering the right code, there should be a secret menu that will appear when you press setup , mine appeared as preference. On this menu, you can find the region. You can fiddle around, you cannot destroy the unit. The info is here: http://www.videohelp.com/dvdhacks/amw-v99/3349 maybe you can read what the other people have done.
May 14, 2007 | Amphion Mediaworks S99 DVD Player
Amphion Mediaworks S99 DVD Player Logo
149 people viewed this question
Top Amphion Mediaworks Televison & Video Experts
Electro Med Services...
Are you an Amphion Mediaworks Televison and Video Expert? Answer questions, earn points and help others
