Sennheiser HD250 - Headphones. My left headphone is not working. I opened the left side(thats the side where cable for bot sides go), and the connection looks ok. They work just fine, and I didn't even use them that much...
beeboy
  • 5 Answers
SOURCE: Audio only plays from left headphone
try to change your baby jack adapter inside your kpex,because it was damage,if it is still under the warranty,bring it to your kpex dealer
Posted on Feb 16, 2008
  • 31 Answers
SOURCE: headphones not playing in iPod
This is either cause by a damaged headphone socket in the iPod or a loose connection. The only way to solve it will involve opening the iPod case and inspecting the daughter board that the headphone socket is on.
Posted on Mar 06, 2008
  • 3 Answers
SOURCE: unable to listen to my wireless
They need a minimum level of signal to switch on the transmitter.
Verify if it works on yet another system.
Make sure you have the right output on your Samsung.
Try to increase the output level of your Samsung...(up the volume, but it may be a fixed output..)
Posted on Mar 08, 2008
00music00
SOURCE: Only hear out of one side of headphones with sansa player - tried 5 pairs...
its the sansa the head phones have to channels inside and one of them i might be broken have a look inside where the headphones go in there are 2 metal tabs if one of them are broken go take it back
Posted on Mar 26, 2008
SOURCE: my sennheiser hd 212pro headphones
I own a pair of Sennheiser 520II headphones with a similar problem. One speaker element is out due to a broken wire. I think the wire can be re-soldered - if done carefully. The wire is hair thin and you may need a magnifying glass to see it clearly. But it just takes a cheap soldering iron and a lot of patience.
And of course, a small piece of similar wire to reconnect the broken leads (which you can either buy a Radio Shack or cannabilize from any cheap broken speaker and use the wire in it as a replacement).
I'm gonna give it a try, since the speaker element appears to be in very good condition otherwise.
Posted on Nov 17, 2008
Left speaker not working
I don't believe it to be a cable or plug problem, so it sounds like it's a speaker problem. I look up the review of these and it could have some kind of circuit built into each side. If it does it could be that. As they are not cheap headphones by the look of it, perhaps worth repairing. But if the speaker has gone, it might be as much as a new pair.
Jan 03, 2014 | Sennheiser HD 558 Headphones
Sound in one ear
I had the same problem, and it is a very simple fix, the cable connection can fall out of the speaker piece on the right side.
I have made a blog post with the steps for removing the cover on the Sennheiser HD570.
Opening the HD570 for repair
Nov 17, 2012 | Sennheiser HD 570 Consumer Headphones
I have the RS120. It worked ok for about 2 years and then the right side stopped working. The left side works just fine. I opened up the sides and it seems that there is no broken solders or anything...
well it seems your right earpiece is started to get broken...clearly saying that the coil has static and would result to an open coil.....try to replace with a new one...good day...
Feb 12, 2011 | Sennheiser RS 120 Consumer Headphones
The left side is not working
You could have a look at my tip on repairing dodgy cables and plugs on headphones. Though if it will be any good with your type of headphone, is up to you to evaluate.
May 11, 2010 | Sennheiser CX 300 Consumer Headphones
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
My right side head set has no sound, left side head set is fine. there is balance control.
maybe the right side of your headset encounter disconnecting of his wire try to open if and reconnect again or replace the wire
Jul 05, 2009 | Sennheiser RS 120 Consumer Headphones
No sound in left sennheiser HD600 headphone
It looks like the speaker has gone. Check with your local authorised dealer for a replacement speaker.
Oct 17, 2017 | Sennheiser HD 600 Consumer Headphones
No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Mar 03, 2009 | Sennheiser HDR 140 Consumer Headphones
 Grubhead
Grubhead
