Question about Sony XDR-S3HD AM/FM Radio
Hello, I own a Sony XDR-S3HD all works very well until yesterday. When I put the Sony on there is NO sound. The tuner is still receiving signals anf the signal strength shows 3 bars and RDS but it produces no sound from the speakers. Hope one can solve my problem. Thanks in advance. John/Holland
2 Suggested Answers
SOURCE: Sony ICF-SW77 no Audio
you can get the service manual online at www.mods.dk
Posted on Aug 12, 2009
The time does not automatically set on my sony alarm clock XDRC706DBP
Afraid I have the same problem and I have to manually set.
good luck !
Jul 07, 2014 | Sony Xdr-c706dbp Dab / Dab Digital Alarm...
My sony 52wx4 tuner will not work. cd and aux does, but not tuner. Lights up but no sound
some of the sony tuners did have inherent problems, if your unit is a cdx-gt260 then most of these had tuner problems. best to change the entire tuner "circuit can/module" in the unit. or check out your sony service center for repair advice/cost. cheers.
Jun 10, 2012 | Car Audio & Video
Iphone4 will not playing music through docking station Sony XDR-DS12IP... Iphone was working with system perfectly until sunday? still manages to charge iphone ? Iphone message iphone not configured...
first return sony and get ihome because sony is bad at docky station(not affending ps) or you can do is take it where you got it and bring the ios deviece and get it checked if it works congrauts if it doesn`t BUY IHOME.
Aug 23, 2011 | Sony HD Radio and Dock Docking Station,...
I have a Sony CDP-CX355 300 CD Player and old Technics SA-5060 receiver and two new Insignia NS-B2111 bookshelf speakers, with old but solid speaker wires. When playing the CD player, loaded with symphonic...
Don't run anything but a TURNTABLE through Phono. That's the only labeled input that's literal. Use any other Line Level input for the CD.
If you don't have anything connected to the Tape loop, use the Tape In connectors.
Feb 18, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
Dont know how to set up the am loop antenna for sony ICF-CS 10iP
You just tip up the loop and fold it over the wire. Keep the loop AWAY from the radio or the loop will pickup the display and make radio noises from the radio itself. Put the loop as far away as possible and by a window and rotate for best signal strength.
Jan 08, 2010 | Sony XDR-F1HD Satellite Radio Receiver
I have lost the mains adapter for my Sony XDR-S50 DAB Digital Radio. Can I buy an universal one that would work in the UK? If so, what voltage etc.? Thanks
Hello
A multi adapter is a great choice, it is inexpensive and works for basically anything. You have a choice between ac or dc.
The voltage increments go up in about 3 violt, mine goes to 16 volt. This should work perfectly for you.
Please rate solution
Best regards
Sep 15, 2009 | Sony Audio Players & Recorders
SONY XDR-S55DAB Stack at display : DAB WAIT
Solution seems to be do not buy small Sony DABs, or any small ones. I have the XDR-S56DBP and have same problem. Was also cursed with 'no ensemble' error. Even worse than the Pure one I had before which lost all of the DAB facility and now only functions as an FM radio. I had a good medium sized Roberts one, but power cable split and I can't find a suitable replacement.
Apr 28, 2009 | Sony Audio Players & Recorders
No tuner output
Some home theatre receivers will not output sound until you ( LOCK INTO ) a radio signal, be sure you have a antenna connected and are receiving a strong signal. Unlike the older model you would receive static sound until you found a station.
Feb 27, 2009 | Gateway Audio Players & Recorders
Have a Denon 685 receiver. Purchased a Sony HD tuner (tuner only --$99). Hooked it up to phono input and it worked. After a while protection circuit clicked in. Used integrated tuner in unit. Worked longer...
if you disconnect speaker wire from rear and the problem is solved you will have a real problem in speaker wiring-you must fix it first or disconnect it from receiver and put new wires instead of.
Jul 16, 2008 | Denon Audio Players & Recorders
Sony XDR-S3HD AM/FM Radio Logo
81 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
