Question about Price Pfister Plumbing
This series 34 faucet is ****.I have to multitask while the sink fills with enough water to wash dishes. Rinsing is another thing. Wish I had rebuilt my old faucets.I don't have a lot of time to waste waiting for water. Takes x amount of water to do job so slowing down flow only wastes time waiting for water. The straw size supply lines get me. the price is the same as older faucets but less material making them means more profit.
  • Ralph Calabrese
    Ralph Calabrese Sep 16, 2010
    Evidentualy txpipelayer has no experience with the new federal requirements pertaining to water flow from new faucets now being sold. These are brand new faucets with a new clean aerator.
  • 20 Answers
You need to clean your aerator is the most likely cause for the low water pressure after the installation of the new faucet.
Posted on Sep 16, 2010
My dishes don't seem to be getting rinsed. They come out "gritty" and none of the food particles are being washed away.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool KUDC03FVSS Builtin Dishwasher
Tablet not melting in the dishwasher and the dishes are coming out dirty
I much prefer liquid dishwasher detergent for this reason. Have you tried this? Also, I find I have the best luck when I start with hot water rather than waiting for the machine to heat the water. I do this by getting hot water to the sink (while rinsing the dishes before putting them inside) and then starting the dishwasher.
Liquid is also easier to distribute when considering the pre wash vs the main wash cycle.
Another thing you might try is breaking the tablet up before putting it in the machine.
The third thing I might suggest is you try powedered detergent for dish washers.
I hope this helps you ... thanks for visiting today.
Jan 25, 2011 | Kenmore 24 in. 16532 - Multiple Color...
The dishes don't come out clean after complete cycle or even after I re did the wash.
Has it always been okay in the past? Do you have the manual, and if so, are you loading it properly. I am not familiar with this particular machine, however there are a few things you can check. Make certain all the spray arms are spinning freely. If there is a "tower" that comes up from the bottom, be certain nothing is blocking the center portion of the bottom rack. Run a load as normal, but stop it after a few minutes. Is there water in the tub and are the dishes wet? If not, determine if the water source is on, and the "fill" solenoid is working. If there is water, and all dishes appear to be getting wet, be certain you are getting a lot of "water action" during the wash. If you listen closely, you should hear a sloshing sound as the machine runs. If not, your not getting enough water circulating. The pump may be clogged, or perhaps there is not enough water coming in. Is your water pressure high enough to fill it completely? I hope I have given you enough things to check in order to lead you to the problem. Let me know.
Oct 31, 2009 | Maytag MDB7100AWB Dishwasher
My washing machine when rinsing the water comes out in a trickle and takes about two hours to fill, it is only 6 weeks new
being a new machine, first thing i would check is the water supply of the faucet feeding the machine. remove machine hoses and run supply water to make sure you are getting normal pressure, like at any faucet. if that is good remove hoses at machine, make sure there was no packaging left on that may have bblocked the line.
Aug 26, 2009 | Washing Machines
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit W 123 Front Load Washer
Kenmore series 70 top load washer - cold water fill very slowly.
The screens in the line are clogged. There is usually a screen in the washer hose at the point where it is connected to the faucet as well as one by the water inlet valve. NEVER REMOVE THE SCREEN BY THE WATER VALVE. As for the one in the cold water fill hose, that can be cleaned or replaced.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore ultra wash
This could be due to lime deposits from your water or very hard water. If you fill a glass from the sink is it real cloudy? Also it could be due to low pressure from being clogged or if you have galvanized pipes they may be clogging up and causing low water pressure which is not rinsing off the dishes with enough water. To test the water pressure in your house turn one sink on and then turn the other one on. If there is a large drop in pressure this means your pipes may be starting to clog up. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 24, 2008 | Dishwashers
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
HElp Dishes not coming clean
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Plumbing Logo
123 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
