Question about LG LSC27910TT (265 cu ft) Side by Side Commercial Refrigerator
Hey our refrigerator has stopped working completely. There is no power being accepted by the machine and it has completelly shut down and will not start up again. What should we do? It is an LG LSC27910TT
  • LG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
Time clock not accepting the time card
needs to be serviced. a sensor may be not working. Try www.gatewaytime.com
Mar 18, 2013 | Amano BX-1600 Electronic Time Clock
My Roland G70 power up problem. .
Open up the Roland G-70 and check if all the connectors and flatcables are well seated. Check also if the power supply is working as supposed to.
Aug 30, 2012 | Roland Music
LCD panel and lights not working
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Mar 26, 2012 | Sub-Zero 642
This is the 2nd time I have had the same problem. After one year the ice maker stops making ice and heats up inside the unit. Viking replaced the unit last year and now one year later I have the same...
could be numerous issues that stop machine from working
but as its outdoors i would remove condensate drain pump
and make it a gravity drain
if drain pump fails will shut down power to unit
Aug 28, 2017 | Viking Refrigerators
My ice marker will not stop making ice the arm
This problem is going to be the ice maker itself. The arm you are talking about is the shut-off mechanism for the ice machine. Just before the ice machine starts to make ice, the arm slowly rises. Then the arm falls down, if there is ice blocking the arm from falling all the way down it will not make ice because there is plenty! If the arm is able to fall down completely, the ice machine will make ice like normal. If your ice maker is making ice regardless of the arms position, something is wrong with the ice maker. Depending on who replaces this, it could cost anywhere from $100 to $200.
May 28, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
The panel for the ice machine and water dispenser has shut off.
I have had the same probelm for over a year. It appears to be a problem in the touch pad w/ribbon connector which Electrolux refuse to accept responsibility for a faulty product. Model E230575DSS8
Apr 20, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Shuts down, interior lite on tho, plug back in and works - stops
You have a bad thermostat ( the piece where you adjust the coldness of the refrig ) . Once it gets to temp and shuts off , it will not tell the system to start again . Next time not running , tap on the t-stat . If it starts , this tells you the thermostat is bad .
Aug 25, 2009 | Avanti 651WT Top Freezer Refrigerator
Hi my camcorder is model vpl600 it is shut down completely
Try to press the reset button, if that dont work it may be that the camara when completelly out for good, sorry.
Aug 11, 2009 | Video Cameras
94 buick centry dose not take refrigerant also ac clutch dose not engage but i can spin it by hand?????
If your compressor shut down, it's probably due to lack of refrigerant. GM's have a safety feature built in to their compressors, if their is not enough refrigerant to power the compressor, it will shut down and require a reset. (disconnect neg battery cable for 20mins). Once the compressor has shut itself down, it won't accept more refrigerant until it has been reset.
Jun 30, 2009 | 1998 Buick Century
LG LSC27910TT (265 cu ft) Side by Side Commercial Refrigerator Logo
282 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
