Question about Dishwashers
Dishes on top two arms not getting any water and cannot find an easy way to remove arms and tube to see if clogged up?
  • donhill622 Sep 10, 2010
    NO THIS REPLY IS UNACEPTILBLE THE COMMENTS WERE GENRIC AND NOT PACIFE TO MY MODEL. i STILL DO NOT KNOW HOW TO REMOVE THE PART NUMBER 8268343. AND WHAT ELSE COULD BE WRONG. WHAT IS THE MOST COMMON PROBLEMS, AND HOW TO DETERMINE THEM.I WAS TOLD BY SEARS THAT THIS WAS A FREE SERVICE . THAT I WOULD NOT BE CHARGED FOR THIS SERVICE
  • donhill622 Sep 15, 2010
    Thanks, this seems to be what i need , but I am having trouble whatching the video. My computer"s problem so I am working on it. Seems I need to fix my computer before i can fix the dishwasher.
  • Dishwashers Master
  • 2,605 Answers
Welcome to FixYa,
The part you`re referring to, # 8268343
example...
Yes, can be difficult to remove. I find removing the top rack to be the best place to start.
However I also find sometimes visual "how to" instructions are better than explanations, therefor I`ve attached a video for you to check out.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
This should help you get to the pump filter, spray arm and check for food deposit, broken glass, undissolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, This will be applicable to most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air.
When you`re finished run it through a test cycle and see how it goes. You may even want to run it empty with just a bowl of "white vinegar" on the top rack for a dishwasher bath.
Let me know how you make out and what you find.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 11, 2010
  • Mark MacDonald
    Mark MacDonald Sep 15, 2010
    the video definately works, I just tried it again. Maybe try lowering the image quality in the lower right hand corner of the video box...it defaults to 360p but may run smoother at 240p or try hitting "pause" thus allowing the video to completely load (buffer) bfore playing it.
    Hope it works, it is very helpful.
    Good luck.
    Regards,
    Macmarkus :)
  • 11,896 Answers
Water is forced through the spray arms of a dishwasher by the unit's pump and motor assembly. The force of the water propels the spray arms, spraying water and detergent onto the dishes on the dishrack. Depending on your model, you may have only one spray arm located on the bottom of the dishwasher, or you may also have an upper spray arm located at the top of the unit above the upper dishrack. There may or may not also be a plastic tower extending from the center of the lower spray arm, whose purpose is to spray an additional blast of water at the dishes.
Remove the lower dishrack from the unit. Reach into your dishwasher and spin the lower spray arm. Take note of whether or not the arm moves freely or if its movement is restricted. It should not be restricted in its path of motion. Now gently pull up on an end of the spray arm. The spray arm should be free to wobble up and down. Next carefully examine the spray arm seams. If they have split or are damaged, the dishes may not receive the amount of water pressure required to fully clean the dishes. What's more, if water is in fact spraying out of the spray arm from its seams, it is possible that it can cause your dishwasher to leak.
If your dishwasher has a spray tower, pull up on it as far as it will go and then let it fall back down. Again, this movement should not be restricted. It should be a fluid and smooth motion. Also, unscrew the spray tower and examine it for any debris or foreign objects. Remove any that you find.
Gain access to the upper spray arm by removing the upper dishrack. Perform the same tests for the upper spray arm as you just did for the lower spray arm. Keep in mind that the upper spray arm may not wobble as much as the lower spray arm.
On a final note, some dishwasher models have a water tube that meets up with the upper spray arm once the upper dishrack is pushed back. It is a good idea to check to make sure this tube is aligning properly with the upper spray arm.
Dishwasher spray arms are removeable. You can take them out and clean them, or you can take them out to replace with new ones.
Disconnect the power source to your dishwasher before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the
Remove the lower dishrack from the unit. If your dishwasher has a spray tower in the center of the spray arm, remove it now by unscrewing it with your hand. You should see a bolt in the center of the spray arm. Remove the bolt and then remove the lower spray arm by pulling up on it. If your particular spray arm is not held in place with a bolt, lift up on the spray arm to remove it from the unit. You may need to rock it back and forth a little to help ease the process..
If there are any washers used with your spray arm, make sure you return them in the same order they came off.
If you are replacing the spray arm, simply discard the spray arm you have just removed, and insert a new one in its place. To clean your spray arm, soak it in warm, soapy water. Rinse it clean with a high pressure spray of water. Return spray arm to dishwasher.
Disconnect the power source to your dishwasher before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel Water is forced through the spray arms of a dishwasher by the unit's pump and motor assembly. The force of the water propels the spray arms, spraying water and detergent onto the dishes on the dishrack. Depending on your model, you may have only one spray arm located on the bottom of the dishwasher, or you may also have an upper spray arm located at the top of the unit above the upper dishrack. There may or may not also be a plastic tower extending from the center of the lower spray arm, whose purpose is to spray an additional blast of water at the dishes.
Posted on Sep 10, 2010
  • Nate Stansfield
    Nate Stansfield Sep 15, 2010
    Have you tried updating or re-installing quicktime player?
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
Leaving grit on dishes that are mainly on top row
The upper spray arm is powered by water from a tube that runs up the back of your machine on the inside. If the connection is not aligned, then the water can't get to the spray arm. My children use to knock mine out of kilter when they loaded the lower section. It's easy to see if the supports are not attached to the upper rack and a simple snap will get them back in place.
You may have clogged jets in the upper spray arm.It will need to be removed so that you can soak it in hot soapy water and then flush it with hot water. You may also need to take a toothpick or tweezer to remove any debris that clogs the jets.
Finally, check the bottom of your door on the inside of the dishwasher. It's amazing the "gunk" that can collect there. This gunk can be redistributed to your dishes. I put some soapy water in a cup and use an old toothbrush to clean this area. Then I rinse twice with hot water. Finally run the dishwasher with 1/2 cup of white vinegar while empty.
This should take care of your gritty dishes. I hope so. If it does, please come back to Fixya and rate my advice!
Jul 21, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes on top shelf do not get clean.
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 13, 2011 | KitchenAid Dishwashers
My Kenmore UltraQuiet 8269644 has been performing poorly. Have cleaned various filters and traps. The spray bars tend to clog with food refuse and now it is leaving a white film on dishes - either...
Also, dishwasher detergents need HOT water, so be certain the water is at 140 degrees. Make sure your detergent is fresh!
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
Jun 12, 2011 | Dishwashers
Hello, I have a portable Moffat dishwasher Model: MRC3210SW159, Serial: AR608530A. We are getting small food bits stuck all over the dishes. Not sure what to take apart or do? Could you please give us some...
And of course, when you're loading the dishwasher, be sure none of the items are resting ON each other. This will prevent the water from circulating and cleaning.
Gritty residue left on dishes. the middle arm doesn't seem to be working
Jun 12, 2011 | Frigidaire Dishwashers
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
528 people viewed this question
Top Dishwashers Experts
Owen Barnes
