Question about Star Logic 17" LCD Monitor
I have a Star Logic LCD monitor. Recently I have been having a problem powering the monitor on. Sometimes when I press the power button or bring it out of hibernation, the screen remains black and the green power light flashes at a rate of about once per second. After 1-3 minutes, the monitor turns on as normal and works fine until it is turned off/goes into hibernation again. This doesn't happen every time, but often enough that I am concerned.
  • 11,361 Answers
First place to check will be the DC filter caps in the power supply section. See example of failed monitors due to bad caps here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 10, 2010
I have fp567s monitor\r\nit often goes silver while starting and it needs monitor off button to be pressed (sometimes twice/thrice) for windows / boot screen to come alive i have re-installed the driver...
The silver hwite/grey screen means that the LCD panel is not getting the signals, 5vdc from the logic board. Try reseating the connections between the logic board and the LCD panel first.
Also check the power supply caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Dec 13, 2010 | BenQ FP567s 15" LCD Monitor
Montior will not come on
internal board on the lcd has blown capacitors you will need to replace those on the power board to bring the monitor back up.
Nov 22, 2008 | Star Logic 17" LCD Monitor
Star logic monitor settings
I typically do capacitor replacement on lcds all the time insde, the board for power will most likely have 1 - 4 blown capacitors, replace these and the monitor should be good as new, btw 1 is a 10 v smallish size you can replace it with a 16 volt same MF.
Sep 10, 2008 | Star Logic 17" LCD Monitor
Star logic 19" lcd monitor
This is most often caused by a serious failure and the power supply is protecting itself and you from fire by cycling the AC off and on.
Aug 08, 2008 | Star Logic 17" LCD Monitor
Star logic 19inch computer monitor power adapter STD-1205
You can use a power supply for a CCTV system. Here is a website that has one, it is for a DVR4220, code STD-1205
Jul 27, 2008 | Star Logic 17" LCD Monitor
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck Housecall101@aol.com
Jul 24, 2008 | Star Logic 17" LCD Monitor
OSD Lock
  • OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Apr 18, 2008 | AOC LM729 17" LCD Monitor
Monitor won't turn on
The inverter power supply logic board has probably goe out. You can get it here or have it fixed.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
Mar 30, 2008 | Dell E176FP 17" LCD Monitor
BLANK MONITOR
the signal stage of your monitor is likely to have a problem, if the cpu is working fine then troubleshoot the signal stage of your monitor or visit a local technician
Dec 06, 2007 | Star Logic 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
