Question about Panasonic Lumix DMC-TZ3 Digital Camera
Accidently pressed against open lens and it retracted and shut off. now it will not come on. panasonic dmc-tz3
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 10, 2010
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
Panasonic Lumix lens does not open all the way
Lumix len goes in and out then I'm told to shut off
Jun 17, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DMC-TZ3 Stuck Lense & No Power
You may be able to free up what is hanging lens by rapping the camera smartly against the heel of your hand, or on a harder surface covered you a cushion of two laps of bath towel. Do not rap the lens itself of course.
If this does not work, you can try puffing a small amount of graphite lube into the two shelled sections of an extended lens and get it to retract and extend a few time. If this works, wipe the extended lens down good with a dust attracting cloth. Graphite lub is used because it does not attract dust, making a friction problem even worse over time, like oil based lub do. Graphite lub is available at any HW store in a small plastic tube made to squeeze, expelling (puffing) a small amount of fine graphite onto a precise locations.
If none of this works, sell your camera to a repairman on an ebay auction, and replace it with a working used, refurb w/warranty, or new one from ebay. Prices are cheap because the TZ3 has been replaced with the newer TZ5, and millions of TZ3s, an awesome camera I own, were sold. .
Sep 20, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera mesaage says turn camera off and on tis has no impact also the lens will not retract
hello, i did get also same message and lens did stay out. did put camera in play back mode and in menu did reset everything. now it works again. maybe i was lucky, maybe this is ,,the"solution.
Jack
Jun 18, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic lumix 5.0
The TZ3 has a design problem with their new automatic lens cover, ie, manual lense cap on TZ1 was illiminated on TZ3.
Make sure your lense cover is completely retracted in front of the lense. If not, nudge it fully opened and see if this solves you problem. If it does, contact Panasonic with your problem. If not under warranty, tell them you want them to fix 'their' problem on your camers. Google it on the net and see how common this problem is.
Apr 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
My Panasonic DMC-TZ3 lost the ability to open the automatic lens cover and therefore no pictures can be taken. I took one picture and a few minutes later I wanted to take another and realized the problem....
Sometimes if you strike the camera, while powered, and against the palm of your other hand, it will open, and may operate correctly for sometime before maybe having to do it again.
This is a very common design problem with the TZ3. I would be sure to get it to a panasonic repair shop before warranty runs out. If it has run out, I would preasure panasonic to fix THEIR design problem for free. Especially if it began to occur during your warranty.
Mar 19, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
194 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
