Question about Microwave Ovens
I have a whirlpool Reverse Osimosis wher 25 model and the holding tank is full but I keep hearing a hissing noise and a bubbling sound that indicated that it filtering water for the holding tank. It runs day and night weather we use water or not. What is wrong?
My Whirlpool microwave MT6120XEB-0 keeps blowing the fuse. Inststalled new fuse and display and timer works. Cooking blows new fuse. It turns on, makes grinding sound and blows a new fuse within a second...
You almost certainly have a shorted high voltage capacitor.
See the safety warnings and help information here.
Chances are you will have to remove the oven from the wall to replace it.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 26, 2013 | Microwave Ovens
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
Mirowave not heat
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here: http://031d26d.namesecurehost.com/mwd/mwd_ad_aug_2008_background.mp3
And what is your full model number from the tag on / in the unit?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Please post a new help request with your brand and full model number from the tag and the answers to these questions so we can help you properly.
May 02, 2013 | Whirlpool Microwave Ovens
I have a GE spacemaker XL1800. the model number is JVM 1842 BD. The turn table has stopped turning. There is a turn table control and that is turned on. how do I go about repairing it? also, wher
The full model number from the tag on the unit would be JVM1842BD001 or JVM1842BD002 without the spaces.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
Jan 07, 2013 | Microwave Ovens
Whirlpool over the range microwave model #gh4155xpt-0 serial # trr4413897 Microwave make loud noise and will not heat.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Aug 18, 2010 | Whirlpool Microwave Ovens
Whirlpool Model #MH1170XSS-0 will not heat
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, you will need to post a NEW help request.
I
n your new post, please include your brand name and the full model number from the tag in or on the unit and your symptoms, as well as the answer to the following questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 07, 2009 | Whirlpool Microwave Ovens
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Grinding noise in microwave
If yours sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range grille or control panel assembly in under 5 minutes.
In most cases, there are just gears inside, with no ball bearings.
One of the pins that hold a gear may have gotten bent or worn, or the gears may just be worn on one side of the teeth, making it
loud in one direction.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Updating the link, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2009 | GE Advantium 120 Convection/Microwave Oven
4175sp microwave has no power to turntable
I assume this is Whirlpool model GH4175sp?
This answer also assumes that yours does not allow for keypad control of the turntable.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Jul 13, 2008 | Whirlpool Microwave Ovens
Microwave, model # jes738wj02
It's normal for it to rotate in either direction. It has to do with the position of the motor and the instantaneous line polarity at the time the power is engaged.
But the grinding noise may indicate a problem...
You can do a quick check. You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
If yours sounds like it's grinding, etc., you may have a bad motor.
To replace it, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
May 14, 2008 | Microwave Ovens
Microwave Ovens Logo
119 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
