Why will my d-link wireless dongle work in my friends house but i cannot get the internet in my own? there are 2 other wireless dongle computers in our house that connect perfectly but mine wont??
  • 537 Answers
SOURCE: D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Posted on Oct 31, 2007
  • 10 Answers
SOURCE: Links Router Unable to Connect to Internet
if you go through the links router manual. it should show you how to reset the router.
Try resetting the router, it always works for me when my internet goes.
This is normal with wireless
Posted on Nov 10, 2007
SOURCE: Acer Aspire wont connect to internet wirelessly.
try to change position of your wireless router it will work.
Posted on Mar 17, 2008
  • 17 Answers
SOURCE: D-Link Airplus di-524 wireless problem
Hello.
The status light is blinking in all dlink models, so that is normal.
The wireless radio issues have 3 possible solutions.
1. This model has a antenna that screws in the bnc socket behind it see if it's well screwed, or substitute it by another if 2 and 3 don't fix it.
2. On the advaced settings of the wireless configuration you have the ratio of radio broadcast from 25% to 100% check to see if it's on 100%, change channel to 11 if neer and 6 if far, make sure you have SSID broadcast enabled.
3. This models allow you to restart the AP unit and the router unit idependently, so it's always good pratice to restart your AP in the tools and system comands menu.
Hope that helps.
Posted on Feb 20, 2009
micromend
  • 748 Answers
SOURCE: My internet connection keeps dropping every 2 minutes!!
That particular series of HP computers has a recall with an extended warranty for just this problem. Call HP, they will have you go through all the first line cures but tell them you know of the extended warranty for lost wireless problems. They'll replace the mother board. Make sure you back up all your data when you send it in. I've sent them nearly a dozen and some they reformatted the hard drives.
Posted on Apr 27, 2009
Can i use connect dongle as wireless adapter
Yes definitely ,I think i need lots more information about router version, IEEE standard.
basically adapter that uses mobile phone networks to provide broadband as a WiFi Dongle while USB WiFi adapter can be used to connect your PC to and existing wirless network provided by a wireless router.
but first you should find out what kind of Internet router you are using and always purchase a Wi-Fi adapter that is compatible with the Wi-Fi standard of your wireless router.
read more information
for more http://www.ebay.co.uk/gds/Buying-a-USB-Wi-Fi-Adapter-Dongle-Can-Make-You-More-Mobile-/10000000177329841/g.html
If you still not able to solve follow us Linksys Router Support .
Apr 17, 2014 | Computers & Internet
Why does my internet keep dropping?
change your connection system
you can get TP link units that plug into the house electrical system and run ethernet cables from the computers on a home network system
works like a charm over any distance on the same power circuit for the house
may be a wireless dongle will fix your problem
Apr 11, 2017 | Motorola Computers & Internet
I have had my fujitsu siemens for nearly 4 years. When I first go it I had huge problems connecting wirelessly. BT did however seem to sort the problem. It was fine for 2 years, but again I'm having to use...
Yes if it's just Bluetooth you're trying to get to work by a new BT dongle. If wireless and BT are on the same card buy a new BT/wireless card This one Desktop 802 11ac Wifi Bluetooth 4 0 Dual band 1300M Wireless AC PCI... Works great. Try to stay away from Intel I had to replace two of them in the last six months. The link above uses Broadcom and works fantastic.
Jun 28, 2017 | Fujitsu Siemens Computers & Internet
I have a belkin dongle but have lost the installation cd can i still connect to the internet without it
Yes, with help from a friend. This is what I did. On another computer with internet access working, go to
http://www.belkin.com/support/ab/c/
Find your exact product number and download the driver. Copy that download on to a USB memory stick. Take it out, plug that into your own computer and copy the driver program on to your computer. Then click on it and install it. It worked for me.
Aug 04, 2010 | Belkin (F5D7050) 802.11a/g/b Wireless...
HOW DO I USE A WIRELESS PRINTER WITH NO ROUTER. I WANT TO PRINT FROM TWO COMPUTERS, THAT BOTH USE DIAL UP INTERNET
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Wireless internet
The 3G mobile internet adapter is a small dongle that you need to plug into a computer.
The software setup is often automatic, and software will be installed by the dongle itself.
After installing you will need to pay for internet traffic, either with a contract and monthly fee, or with a pay as you go contract.
Fees vary depending on your country and on companies.
Here is an example of 3g adapter for UK MOBILE BROADBAND MODEM HUAWEI DONGLE 3G USB MODEM.
Better to buy adapter, sim card, and eventually cotract all from same company at a shop.
Feb 10, 2009 | Gateway Wireless-G PC Card (6002547)
Technika bluetooth class 2
go to google type in bluesoleli driver3.2.2.8 this take you directly to the download you need
Dec 29, 2008 | Adapters.com Bluetooth USB Adapater, USB...
Internet
There are a few ways you can use wireless to get the laptop online. The easiest way would to buy 1. Wireless Router and 2. Wireless USB Adapter. Follow link for some pretty good instructions to setup a home wireless network.
http://lifehacker.com/software/wifi/geek-to-live-set-up-a-home-wireless-network-162754.php
Chris
May 28, 2008 | Computers & Internet
Wifi Dongle
function PopupWindow(URL, WIDTH, HEIGHT){ var winleft=(screen.width-WIDTH)/2; var winright=(screen.height-HEIGHT)/2; day=new Date(); id=day.getTime(); eval("page"+id+" = window.open(URL,'"+id+"','toolbar=0,scrollbars=1,location=0,statusbar=1,menubar=0,resizable=1,width="+WIDTH+",height="+HEIGHT+",left="+winleft+",top="+winright+"');"); }
USB WiFi Dongle
Product reference: 11590 Here is some Technical data on your wireless adaptor. There is also a link at the bottom where you can download the driver for the operating system you are running.
" src="http://www.mobilefun.co.uk/graphics/rightarrow.gif" width="10" /> Description The USB WiFi Dongle easily connects your USB-equipped desktop or notebook computer to your wireless network for internet and file sharing. Desktop users can now join the network with the ease of a USB plug-in, without opening their PC cases, laptop users can enjoy the benefits of staying mobile-while connected to the internet.
By adhering to the 802.11g wireless standard, the USB WiFi Dongle is capable of streaming video and transferring large files across a wireless network. You will most likely need this if you have a bought a wireless ADSL or cable modem and wish to connect your PC to the internet or other PCs on the network wirelessly. The USB WiFi dongle is also compatible with all mobile phones and PDAs with WiFi connectivity.
Features:
  • Versatile use with Desktop PC or Laptop Computer
  • Portable, compact, pocket sized design
  • Compatible with IEEE 802.11b (11Mbps data rate).
  • Compatible with IEEE 802.11g (54Mps data rate).
  • Dynamic data rate scaling at 6,9,12,18,24,36,48 and 54Mbps for 802.11g.
  • Support wireless data encryption with 64/128 WEP for security.
  • Support infrastructure networks: Access point and ad-hoc network.
  • Supports WPA enhanced security.
  • Supports DFS/TPC for European operation.
  • Friendly user configuration and diagnostic utilities.
  • High speed USB 2.0 interface.
Technical data:
  • Chipset: SiS 163U.
  • Standards: IEEE 802.11b, IEEE 802.11g.
  • Frequency Band: 2.4GHz ~ 2.483GHz.
  • Data Rate: IEEE 802.11b, 1, 2, 5.5 & 11Mbps.
    IEEE 802.11g, 6, 9, 12, 18, 24, 36, 48 & 54Mbps.
  • Transmitter Power: 17 dBm.
  • Receive Sensitivity Operating at 11Mbps: -80 dBm @ 8% FER.
  • Operating Range: 100 - 400m, depending on environment.
  • Antenna: On board chip antenna.
  • Security: 64-bit or 128-bit WEP/WPA/TKIP.
  • I/O Interface: USB 2.0.
  • Size: 58 (L) x 23(W) x 9(H) mm.
  • Weight: 9g.
System Requirements:
  • Windows 98SE/ME/2000 and Windows XP.
  • Pentium 233 MHz or higher.
  • 32 Mb of RAM under 98, 98 SE, Millennium & NT 4.0 with Service Pack 5.
  • 64 Mb of RAM under Windows 2000 and Windows XP.
  • 100 Mb of disk space.
rightarrow.gifDriver Download To download the latest drivers for Windows 98 or higher click here.
Apr 14, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
