Question about Hitachi EC2510E 5.5hp Gas Air Compressor
Looking for unloader popoff assy on ec2510e - Hitachi EC2510E 5.5hp Gas Air Compressor
    President:
  • Hitachi Master
  • 1,388 Answers
Part is available here :http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/hitachi/EC2510E
Factory part is very expensive.
If you are good at plumbing you could use a generic unloader for about 1/3 of the price, available at www.grainger.com The generic valve has 1/2 npt female threads on both in and out ports. Good luck
Posted on Sep 11, 2010
What causes popoff valve to popoff on 2005 Kia Sorento while adding freon
High pressure restriction look at the following components #1 overcharged system #2 condenser fans not operating when compressors on. #2 plugged or stuck closed expansion valve (oriface Tube) #3 restricted condenser.
Apr 07, 2014 | 2005 Kia Sorento
Pressure off and on every few seconds with my karcher 3000BH
hi there rjcomer2
here is web site for parts
http://www.ereplacementparts.com/karcher-2500-11944010-pressure-washer-parts-c-33388_33389_33973.html
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
hope it helps
pauly46
May 20, 2011 | Karcher 2500 PSI Pressure Washer
Can i use a impact wrench with my hitachi ec2510e gas air compressor
Yes, but it may drain your air supply quickly and you might have to take little breaks and wait for it to fill up again.
Feb 04, 2010 | Hitachi EC2510E 5.5hp Gas Air Compressor
Motor will not crank when air is in tank.
you are supposed to use the unloader valve to start. when air is in tank the starter motor is not only turning the motor but also trying to compress air. this very hard on the whole unit. the unloader valve should have what looks like a loose lever. lift the lever and it pulls the attached rod. after motor starts and runs put back to rest position
Nov 14, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
Attwood RV Water heater model GC6AA-10E overloads breaker when
I would remove the heating element from the hot water tank. Take a look at it as it is probably fried from due to turning on the power to the tank when there was no water in the tank. If it looks ok still do a continuity test on it. I believe that is your culprit.
please mark this answer as a fixya!
Mar 09, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Gas air compressor shuts down
IS IT BUILDING TO THE UNLOAD PRESSURE AND THEN STALLING OR JUST SHUTTING DOWN ANYTIME. IS THE UNIT SITTING AT AN ANGLE?
DOES IT WORK FINE WITH THE LOW OIL SWITCH UNPLUGGED? UNPLUG SWITCH AND LEAVE IT UNPLUGGED FOREVER.THEY'RE ALL P.O.S.
Feb 14, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
NEEDS PARTS FOR COMPRESSOR WHERE DO I GET THEM
go to Hitachipowertools.com and type in your model number and you can get a schematic for this tool and also order parts online. Let me know if you need anymore assistance
Feb 09, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
Hitachi EC2510E 5.5hp Gas Air Compressor Logo
142 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
