Question about Microsoft Xbox 360 Console
My xbox has 3 flashing red lights on front. What does this mean
    Scholar:
  • 119 Answers
It means your system has the dreaded RROD Or Red Ring Of Death,
If you turn the system on and hold the sync button and then hit the eject button, You can find its code you will have to do it 4 times, 1 light means 1 2 lights means 2 3 Means 3 and 4 lights means 0.
You can usually get a code like 0020 0102 and so on, below is a link that will tell you what each error code means,
also look at the back of your system locate the manufacture date, If it's within 3 years of that date don't open the system call microsoft and have them fix it for free.
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Posted on Sep 10, 2010
SOURCE: flashing red and green light in xbox
How do we reflash the bios?
Posted on Jan 24, 2008
J4XXN
  • 182 Answers
SOURCE: xbox 360 has stopped working
it sounds like its an overheating prob or something similar, ive heard that microsoft are extending there warrantys from 1 years to 3 years for anyone having the red light problem, so phone them up, phone number in warranty book. explain problems and find out if its covered on your warranty. hope this helps.
Posted on Feb 14, 2008
SOURCE: Xbox 360 3 red bars
the GPU has become losse ring in and see what they can do for you.
Posted on Aug 08, 2008
Gills1
  • 94 Answers
SOURCE: what does 2 flashing lights mean on an xbox 360?
The two red flashing lights on the left side of the circle indicate the thermal limit has been reached. (over-heating) Check to see if the fan on the back of the unit is blowing air. There are external fans that can be added to keep the GPU. (Graphics Processing Unit) and CPU (Central Processing Unit) temp down. Keeping the temp down can prevent the dreaded RRD. (Red Ring of Death) Here is link as an example of a cooling fan. http://www.gamerepairparts.com/xbox-360-cooling-.html
Shop around and find one that you like. Remember, when it comes to these computer chips, cooler is safer.
Posted on Dec 31, 2008
  • 1093 Answers
SOURCE: what does 2 flashing red light mean on an xbox 360?
2 red lights is the overheating error, you will need to try and dust out the console, or what you can do is send it in to get it fixed or use a good guide to fix it
Posted on Nov 27, 2009
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
3 flashing red lights on the front console power supply is ok
3 red lights on the Xbox 360 is the most common error and it means "General Hardware failure. To fix this you need to stop the amount of heat that the GPU and the CPU is taking.
To do this you can use the recommended guide that has been on the market for 3 years or you can send it in.
Feb 28, 2010 | Microsoft Xbox 360 Console
When i turn my xbox 360 on one light in the bottem right corner flash red and it reads E 74 error but when i unplug the xbox from the t.v it doesnt flash red, does this mean we need a new wire
one red light means the video card is dead not the cord and unfortunately cannot be fixed and to make it worse this error is not covered by warranty, if you want it under warranty tel microsoft wen you ring that it has 3 red flashing lights (RROD) not 1 as this error is covered by warranty
Jun 30, 2009 | Microsoft Xbox 360 Console
Red light blinking on front of xbox 360
How many red lights flashed? One, or three?
One means that your harddrive isn't seated correctly.
Three means that your console is more or less screwed, and needs to be repaired by Microsoft.
Apr 10, 2009 | Microsoft Xbox 360 Arcade
Three red lights
Follow this steps:
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Good Luck
Apr 03, 2009 | Microsoft Xbox 360 Console
Red lights flashing
3 Red Flashing lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 25, 2008 | Microsoft Xbox 360 Console
it is the ring of death it costs money to repair
Aug 26, 2008 | Microsoft Xbox 360 Console
Hi ! This is call the Ring of Death. You have to send your Xbox back for a free repair or an exchange. Those 3 lights mean that their is an internal problem whit your console and Microsoft have put a new waranty system that allows you, for 3 years since you have buy the console, to return it and the gonna repair it or exchange it for you, and all that, for free
Aug 05, 2008 | Microsoft Xbox 360 Console
Red light flashing not working at all
witch onse are flashing if the top right hand and bottom are flashing i think it means harddrive faular and u need to take it in
May 10, 2008 | Microsoft Xbox 360 Console
Three red lights flashing
When someone say that his/her Xbox is having 3 red lights Flashing problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Apr 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
88 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
