Question about Quantum SuperLoader 3 LTO-3 Tape Drive
Can a Quantum SuperLoader 3 have it's drive upgraded from a LTO2 to a LTO4?
Yes, it can
Posted on Feb 01, 2011
My Ca Arcserve is showing that the quantum superload is constantly busy. I can not do anything as it also says that it is busy. I have shutdown and restarted the quantum drive a few times and all still...
power down both the library and computer, disconnect the library, power up the library. Check the operator panel of the library for an online ready status.
Jan 13, 2011 | Quantum SuperLoader 3 LTO-3 Tape Drive
I am getting a DRV PREV REMOVAL TYPE (46) message on display, every time I try and Inventory a tape or run Lable Media.
I have two of these Quantum SuperLoader 3 (with LTO3 drives) and one does keep giving me the same hassle. I haven't figured out how to fix this, but I've gotten past the error: disconnect the autoloader from the host computer (i.e. or stop rsm, mtx, or whatever controlling sofware you use), reboot the autoloader, get the tape out of the drive (e.g. move command from the autoloader's console or web interface), insert a cleaning tape (a few times), reconnect everything (i.e. start back up your controlling service).
Nov 29, 2010 | Quantum SuperLoader 3 LTO-3 Tape Drive
I can't remove the left magazine from a Superloader 3. The unit has failed and I need to remove the tapes. The eject magazine does not work, it doesn't pull the drive gear back.
I found this solution on line and it worked for me. Believe it or not I used a butter knife and stuck it between the magazine and mail slot close to the bottom. You will hear a click and the magazine will pop out. It is like using a paperclip for a stuck CD. Make sure you power the device down and unplug it.
Oct 01, 2010 | Quantum SuperLoader 3 LTO-3 Tape Drive
Superloader3 , don't recognize real capacity of tape
this may be a limitation on your motherboard. please check if your motherboard supports this much capacity. If you have another pc or laptop that is about a year or two, check if they would recognize the the capacity of the drive correctly. if not you may want check with quantum about their drives.
Jun 19, 2010 | Quantum DLT-V4 DLT Tape Drive
Elem Table Bad (2B) error
The element error usually points to the drive, the best thing is to do is run the full diagnostics for the drive, and see what other hardware codes you receive, if it still points to 2b, then it is either the drive or the solenoid of the magazine failing. If you have a two magazine setup, just reverse the other magazine and test it that way.
Apr 16, 2009 | Quantum SuperLoader 3 LTO-3 Tape Drive
Quantum superloader not showing in windows device manager
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Nov 13, 2008 | Quantum SuperLoader 3 LTO 2 Tape Drive
Quantum Superloader remove jammed tape
You have to disassemble the unit and remove the tape. Chances are it's stuck in the carousel (the round thing at the front that spins tapes and plugs them into the drive).
May 06, 2008 | Quantum ATL SuperLoader Ultrium Tape Drive
Loading Media
Same problem with Backup Exec 10d and Superloader 3 LTO-3.
This is not my first problem with this Superloader. I think it is garbage and will likely be in the garbage very soon. Very expensive garbage unfortunately.
Mar 05, 2008 | Quantum SuperLoader 3 LTO-3 Tape Drive
ATL Superloader with LTO2 drive
The LTO family drives all support a tape-related diagnostic spec called TapeAlert, and if you use a software product that decodes it and can dump out all of the settings related to firmware, error logs, etc ... then I have no doubt it will provide root cause. Check out http://www.santools.com/smart/unix/manual (the code is also ported to windows. There are links for TapeAlert reporting) Or go to http://www.tapealert.org for info on the spec.
Feb 08, 2008 | Quantum ATL SuperLoader Ultrium Tape Drive
Quantum SuperLoader 3 LTO-3 Tape Drive Logo
325 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
