Question about Emerson Heating & Cooling
Model EQK1350 shroud destroyed by hail. From whom can I purchase a new shroud?
  • 944 Answers
There is no way to buy the Emerson Air Conditioners parts in online or outside any shop.You can get shroud only from there service center service center.
Make a call to the above no and ask their local service centre.You can get the part in that service centre.
Heating & Air Conditioning Heating & Air Conditioning 8100 W. Florissant Ave. St. Louis MO United States Phone: +1 314 553 2000
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 10, 2010
Rubber button for PTT on model 430 RM hailer
did you check the manufactures web site
Apr 20, 2014 | Radio Communications
Removing the shroud to get to the spark plugs on 2013 Chevrolet Traverse.
The easiest way to get them out is to use a PICK and get under the Edge. Some will BREAK... Get some Spares.....
Apr 06, 2013 | E3 Spark Plugs Motorcycles
New Rover engine ignition unit.
this is a old one ,remember the old V8 well ,as when the vacumn unit failed it wouldnt start from cold ,advance timing by twisting distributor and it would start then reset timing and it would run all day but when cold the following day? now iam not sure here but look in the new wire and iam wrong here no doubt but it has two wires and a shroud around them and i think this shroud has a pin connection to earth hence your 3 pins but without my head under the bonnet to confirm i cannot be sure as the old gray matter declines in old age and i havent seen one of these cars in many a year so if iam right just leave shroud connection disconnected .My neighbour has one of these cars laying in the garden at last count its all their but the sun has destroyed the paintwork and the interior but no rot anywhere as this is spain and here their is no rain or very little
Jan 23, 2013 | Land Rover Range Rover Cars & Trucks
How to repair hail damage from hood
There is a new system that pulls dents out. Basically, you clean the area where the dent is, stick a plastic gadget to it, wait for it to dry and then use a tool that pull the dent up until the glue breaks from the hood. See the videos. You can Google 'dent puller'.
repair hail damage from hood Google Search
May 21, 2012 | 2002 Chevrolet Trailblazer Ext
How do i replace a broken dryer belt?
Unplug the dryer and remove it to the outside (if possible). Pop the top. Remove the front, then the shroud (if applicable to your model). Get the drum out and give it a good vacuum. Place the new belt around the drum making sure it is not twisted. 99% of all dryers the ribbed side goes down on the drum. If the belt is twisted it will be destroyed the minute you start the dryer. Not sure what brand you have so I inserted some links above. Good luck on your dryer repair. Get your belt here, here or here.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 25, 2011 | Dryers
I need to replace a broken shroud on a Duo-Therm Brisk Air Model # 59715.531 Where can I purchase a matching shroud?
americanrvcompany.com Once on the site go to air conditioners on left hand side then Dometic A/C. They should have what your looking for.
Jul 05, 2011 | Dometic 57915531 Air Conditioner
When i turn it on it shakes like something is loose. The shaft is straight,could the fan brackets be loose? ...
Could be, be also you need to check both fan blades. One could have a dirt dobber nest or something ellse on it. This will cause the motor to be off balance.
May 18, 2011 | Heating & Cooling
I am trying to buy a shroud for my coleman rv ac unit its an older rv 1995 and i have found so far that the shrouds have changed and everywhere i look they want a model number. Any info on the outside have...
Sorry we have no referral service here or anyway to locate the parts for you. That said my friend had to have his custom made. He is in Calif and I don't know where he had it made.
Jul 24, 2017 | Coleman Mach III Air Conditioner
Removing the cabin air filter on a 2001 mitsubishi galant
Open the glove box and empty the contents. gently push the glove box to the left and slide the stop toward you. Now slide the box to the right to get the left stop unhooked. Letting the glove box hang, look at the long thin plate on the fan shroud and undo the two screws holding it in. Now you can slide the cabin filter tray out of the fan shroud and replace the paper element. If you look at the fan shroud and see the rectangular slot but there are no screws in it , the cabin air filter has not been installed in your model. The rectangle can be cut out with an Exacto knife and the cabin air filter can be installed in the slot. You can purchase the cabin air filter tray, cabin air filter, and mounting screws at the Misubishi dealer. I purchased one out of an Eclipse at a salvage yard for $5 , washed it, and installed a new $10 dollar aftermarket paper element. I no longer have dust on my dash and it only cost $15.
Mar 27, 2011 | 2001 Mitsubishi Galant
Heating & Cooling Logo
88 people viewed this question
Top Emerson Heating & Cooling Experts
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
