Question about Bosch 23 in. SHU3302UC Built-in Dishwasher
My Bosch made a moaning sound and never got water to wash dishes. I tried to cancel the cycle and it would not cancel. I am guessing I have a bad controller? Can you tell me how much that piece would cost?
    Problem Solver:
  • 6 Answers
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Posted on Oct 05, 2010
  • NoMorTosh4Me
    NoMorTosh4Me Oct 18, 2010
    Go to the Bosch website...there is already a recall repair notice for this model...the controller is faulty and may cause a fire! Call the number at the website and get a recall repair appointment set up.
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch dishwasher SGS55M2 leaves dishes wet
Are you using drying agent?If not you have to use it in bosch dishwashers.When the cycle is completed is it hot,steam rolls out.if not you have a heater problem or thermostat problem.
If you need more info please ask
Feb 05, 2009 | Audiovox Bosch 718 World Cellular Phone
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Oct 13, 2008 | Bosch Dishwashers
Dishwasher bosch beeping noise
Found this on the Bosch website..... see 2nd to last step
The Cycle Completion Signal
This Cycle Completion Signal is a tone that sounds to alert you when your dishwasher
finishes washing and drying your dishes. You can either disable the tone or set the volume.
To activate:
· P ress and hold the right “Cancel Drain” button then press and hold the On/Off button.
· When the light on the “Cancel Drain” button you are pressing illuminates and the tone
begins to sound, release both buttons.
· P ress the right-most “Cancel Drain” button until the tone is either at the desired volume
or is silent.
· P ress the On/Off Button. The Cycle Completion Signal is now set.
Sep 27, 2008 | Bosch Dishwashers
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHU43
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
Nov 15, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
283 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
