Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 code flashes after washer starts (Cabrio Model WTW6200SW2
  • 15,935 Answers
A fault code of "F" then "1" flashes when there is a primary control failure. You will need to replace the machine/motor control assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
    Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
    Washer Components
    Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
    WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
    Maytag Bravos Washing Machines
    MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
    Kenmore Oasis Washing Machines
    110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
    NOTE: For All Error Codes
    First press PAUSE/CANCEL once to clear the error code.
    If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
    flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
    Is the pressure transducer hose kinked, disconnected, or punctured?
    Back to Top
    Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
    Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
    "HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
    "dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
    Check for items caught in the lid keeping it from closing completely.
    Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
    The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
    Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
    (Stored Error Code F32) Check the following:
    Is the drain hose or pump clogged?
    Is the drain hose higher than 96" to reach the drainpipe?
    Is the Drain Pump Running?
    Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio, WTW6200SW2, 4 yrs old. shows F1 code at beginning of wash and rinse cycles. Is this a recall issue on this model? If so, what is the name of the part?
    Hi
    Yes this is a recall issue and whirlpool is aware of it, the part that is replaced under F1 Error is the control board and they are the ones who pay for part. Hope this helps...please post back for further assistance.
    Daniel
    Aug 05, 2011 | Washing Machines
    Wtw6200sw2 keeps giving F1 code when filling with water. Have to stop the washer and restart 6-7 times during wash load. Customer service tells me this part is not covered on this model only on other...
    you will need a new machine motor controller part# W10189966 which is located in console
    Three screws in back of console and head completely flips forward.
    Jun 19, 2011 | Whirlpool WTW6400SW Cabrio Washer
    I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
    F1 (F60-68)
    Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
    See Accessing & Removing the Electronic Assemblies.
    F1 flashing on the display indicates a primary control failure.
    "F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
    The link below lists Cabrio failre codes.
    http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
    Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    When I start the washer the dial flashes and says F1
    The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
    Thank you !!
    Aug 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error code
    check the FixYa website for other solutions for your model, look for one with 29 postings........
    Feb 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 code whirlpool
    whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
    Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washer is showing a code f1
    press PAUSE/CANCEL once to clear code. press start.if code reappears call for service
    Mar 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    433 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
