Question about RoadPro AC/DC Power Inverter 80/100w
I need circuits of inverter JASIC TIG 300 - RoadPro AC/DC Power Inverter 80/100w
Have a Miller Dynasty 300 that won't tig weld, displays HELP 12 code. Suggestions??
Some welders have a resistor that is obvious and accessible but to give an error code it is likely something else inside. You'll have to look at the circuit board for a component that is burned. If you are lucky you will find a fuse.
Nov 21, 2013 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Jasic welder repair
Sorry, no question here. Next....!
Jun 06, 2012 | Welding Tools
Tusten tip keeps sticking what am i doing wrong i have rockworth inverter
Make sure the tungsten tip is sharp, not too far from the nozzle and try not to let it touch the metal or molten pool. Also make sure you have an adequate gas feed
Feb 23, 2011 | Inverter 220 Volt Tig Arc Welder
Giant inverter tig mma111 230 volt
check if the load on it is not more than its capacity and check the batteries if they are still in good condition
Nov 16, 2009 | Inverter 220 Volt Tig Arc Welder
Looking for parts for saf presto 135 inverter welder
Hi
my name is Rob, I may be able to help
What parts do need?
this link is for the current models
http://www.saf-fro.com/en/saf-fro/plasma-cutting-1.html
Saf have a base here in the UK
SAF WELDING
2 Low March Industrial Estate Low March, Daventry, Northamptonshire NN11 4SD
p: 01327705511
if the parts you need are generic, I can help.
If you need circuit boards repairing or torch parts I can help
Regards
Rob
Feb 07, 2009 | Inverter Welding Tools
Bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Dec 18, 2008 | Welding Tools
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Dec 13, 2008 | Inverter 220 Volt Tig Arc Welder
RoadPro AC/DC Power Inverter 80/100w Logo
139 people viewed this question
Top RoadPro Electronics - Others Experts
jdthefixer
deton8 von Splosion
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
