Question about Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum
I have an ultra vision turbo, but its not vacuuming. what would be the problem and is that fixable? ps, its not the filter because i already have checked.
  • 1 more comment
  • Jim Parker
    Jim Parker Sep 10, 2010
    Does the beater bar spin?
    Jim
  • ahmed_resan Sep 10, 2010
    well the bar spins but it the vacuum does not **** any air in.
    yes it does but the vacuum does not seem to **** any air in
  • 1,040 Answers
Well, more than likely the belt that drives the beater bar has stretched out of shape and you need to replace it. It is very cheap to fix and you can do it yourself.
Jim
Posted on Sep 10, 2010
  • 2 more comments
    ok i will try this out
  • Jim Parker
    Jim Parker Sep 16, 2010
    Did this help?
    Jim
  • ahmed_resan Sep 17, 2010
    nope, i tried. they belt was perfectly fine. the problem is the vacuum not the belt. the vacuum is not pulling any air in
  • Jim Parker
    Jim Parker Sep 17, 2010
    The belt doesn't have to look bad in order to be bad. The beater bar may even spin, but just not fast enough. If it is stretched out, it will slightly spin on beater bar.
    And you have checked the filter. How about any obstructions that may be blocking the air.
    If there are no obstructions, and you have described everything that the vacuum is doing, then I believe if you put a new belt on the problem will be solved. Otherwise, that all I can help you with.
    Good Luck!
    Jm
Throws dust all over. Missing hepa filter. Is that the problem?
Of course. The filter is there for a reason and it also maintains pressure. But also make sure that the seals to the container are good and that it is located correctly.
Apr 23, 2016 | Dirt Devil Ultra Vision Turbo Bagless...
Dust Devil UD40180 repair manuel
Mate I just googled Dust Devil UD40180 repair manual and found this link, I hope it helps... If not then you google Dust Devil UD40180 repair manual It might give you some ideas...CHEERS
http://www.ereplacementparts.com/dirt-devil-ud40180-ultra-vision-turbo-bagless-upright-vacuum-parts-c-36976_37103_37186.html
Mar 12, 2016 | Dirt Devil Ultra Vision Turbo Bagless...
How do I unstop vacuum so that the dirt moves through the hose? Vacuum has suction but wont move the dirt through to the bag less container.
If you can disconnect the hose and feel vacuum at the hose connector, that indicates that the hose is plugged. Disconnect both ends of the hose and hold the hose over a plastic garbage band to ketch debris and shove a broom handle through the hose to dislodge any obstruction. Reconnect the hose and test for vacuum.
Feb 22, 2015 | Dirt Devil Ultra Vision Turbo Bagless...
No power
My dirt devil just did the same thing to me. I cleaned the filter super good, checked all the hoses for clogs and the brush for tangled strings. Plugged it in and it worked! Yay!!! Hope this works for you too. Linda
Mar 18, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
I don't know how to change the belt on the dirt devil ultra vision no manual
Take all the screws off the bottom to access the beater bar than slide out (belt will also be right there ) just slide a new one on......
Jan 27, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt devil ultra vision turbo - how to change filter
remove the dirt cup, the top part should turn a little bit and then separate ( look were the clear plastic meets the colored top you might see a little picture of a lock and a open lock turn the lid towards the unlocked position , the filter should be in there
Sep 17, 2008 | Dirt Devil Vacuums
Filter clogs with every use
What should I do when the dirt Devil Vacuum clener doesn't **** up dirt ?
Sep 10, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Is there a reacll for the dirt devil ultra vision turbo bagless vacuum?
Go to the store and read the recall announcement.
Aug 25, 2017 | Vacuums
Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
140 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
