Question about Maytag Dryers
Model no. mdg3000aww Sometimes the gas will turn on to heat but will stop before the cloths are dry. Then there are times when the gas will not go on.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Maytag quiet series 100
when on time dry the dryer counts down like a clock,when on auto or more or less the heat comes on until hot then when the heat cycles off the timer will avance,when it calls for heat the timer stops advancing and the heat will come on again until clothes are dry.so you either have no heat,bad sensor or you can try wiping it off,if you use cling free sheets the sensor can get a film on it and then can't sense the clothes,try hitting it with sos or something that will clean it.do you have heat and is it gas or electric,if you can send model number it would be helpful
Sep 17, 2013 | Dryers
THE FIRST TIME THE DRYER STOPPED HEATING THE CLOTHES THE FLAME DIDNT KICK ON AT ALL. SO WE REPLACED THE HEATING FUSE AND IT WORKED FINE FOR 8 MONTHS. NOW THE HEAT COMES ON BUT DOESNT STAY ON LONG ENOUGH TO...
heatman101
Jan 26, 2011 | Whirlpool LGR4634J Gas Dryer
May Tag Gas Dryer Model MDG3000AWW - Dry works but no heat, more dry/ less dry lights flashing. Whats wrong? How do I get heat again?
it is either your glow coil or it is your ignitor
open the door and remove the four screws
take the front panel off.
leave the door attached so you can test the dryer
be very careful not to touch any wires while you are doing this
now close the door and turn the dryer on
does the ignitor turn on?
if yes that is good
does the ignitor glow and no flame?
sometimes it will take a minute to show it's problem
if the ignitor glows and no flame replace your ignitor coils
make sure to turn the power off when replaceing the coils
Aug 24, 2010 | Maytag Dryers
Maytag MDG3000AWW Hard starting
your motor bearings or idler tensioner bearings are going dry and need repl
Aug 03, 2009 | Dryers
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Dryers Logo
82 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
