Question about Canon imageRUNNER 3300 All-In-One Laser Printer
In canon ir 3300, the printer log is active, but the printing page is not coming to the Spool. how to resolve the problem?
  • 480 Answers
if the printer is not spooling, it only means that print spool service is no functioning properly. there is a way to restart the spooler.
press the windows logo key ( between Ctrl and Alt) + R >
type on the box 'services.msc' >
then locate the print spooler and double click on it >
click on drop down and choose diable >
then enable it again >
this time click on the start button to start service again.
then try to print a document again.
This should resolve the issue with the spooler.
If it still nt printing out. Uninstall the printer and reinstall it again >
then do the restart of the spooler and print again.
cheers!!
Posted on Sep 10, 2010
My canon ir 3300 machine showing continues printing but not coming any copies out
***Manually clear the print queue***
1) Open the "Services" panel. The easiest way to do this is click "Start" and type "Services.msc" (no quotes) in the search box.
2) Scroll down the list of services to find and select "Print Spooler". Click "Stop" in the left panel.
3) Open Windows Explorer ("Computer" in the Start menu). Navigate to the spooler directory (typically "C:\Windows\System32\spool\PRINTERS") .
4) Delete the files in the directory.
5) Go back to the Services panel and click "Start".
Dec 04, 2015 | Canon Office Equipment & Supplies
Canon ir 3300 printer has dark part in page not apper in print what is problem
dear
If the dark portion of the page is out side of the image scanned, then there may be chance of light passing to the scanner through platen glass.Pl. check the top cover and whiteness of the flap.
If the scanning through the PC has the same problem then the SHADING adjust to be done.
Thanks
Feb 21, 2015 | Canon Ir 3300 B/w Copier image Runner...
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
Nov 02, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Ir 3300
Set print settings to print as image. Also make sure to spool printing.
Sep 19, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Black bande IR 3300
Most probably you need to replace the drum unit. If you have any idea what was the copy count when the drum was last replaced and since then around 50000 prints are done, new drum is needed.
Apr 28, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
124 people viewed this question
old marine
old marine
