Question about Roper REX3614KW Electric Dryer
My roper rex3614pwd is bloeing cool air every thing else works..what is wrong with it
  • Roper Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Posted on Sep 11, 2010
I have a roper model #REX3614PWD I opened it to check cloths shut the door wont start back up .....
First, check the door switch. You should here a click when you push and release it. Post back the results.
Nov 14, 2012 | Dryers
I have a roper changed heating element. Still blowing cool air. Sister didnt tell me it only comes on in cooldown cycle. Wats could this be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 17, 2011 | Roper Dryers
I have 3 ports for cold air and only 1 is getting any through it
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 08, 2011 | Roper Refrigerators
It is running but only one port is getting cold air through it.
heatman101
May 08, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
Have a roper side by side Model # rs20ckxaloo. the refrigerator works, but the freezer isn't keeping things frozen. just cold like a refrig.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | Roper Refrigerators
Roper top freezer works but not the bottom
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 16, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Where does freon go?
If freezer is working the freon is fine. There is a air flow problem. Air has to circulate between the frig side and the freezer side to cool it.
Eric
Nov 21, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Roper model # RT18DKXFW01 not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
fgjfd
Aug 14, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper REX3614KW Electric Dryer Logo
389 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
